Old 05-31-2015, 07:53 PM   #1
Leak in camper
The DW and I just got back from our shakedown cruise in our new to us 23lb,and we encountered lots of heavy rains while we were out. One afternoon I was sitting in the dinette listening to the radio and I noticed that there was a small drip coming from the cabinet where the radio/DVD player is at,I'm suspecting it's from the radio antennae .... So my question is this... If that is where it's coming from what do I need to use to seal it up?
cruiser1701 is offline   Reply With Quote
Old 05-31-2015, 08:10 PM   #2
Cyber Phrenologist
Radio's Avatar
You'll probably want DICOR lap sealant, comes in regular and self-leveling. The regular stays where you put it. The self-leveling is a bit "runny" and spreads out evenly (sort of) before setting up. Both are easy to use in a caulking gun, fairly cheap and available at any RV supply outlet. The chemistry is made to work with your rubber roof.
If this is a used trailer I'd get 3 -4 tubes and take a "shotgun" approach. Also look for cracks in skylight bubbles, plumbing vents, that sort of thing.
Inspect the seams along the end-caps and look for tears in the roof membrane.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
camper, leak
