Old 06-23-2019, 07:16 PM   #1
Level up system
Hello folks new to the group. I have a 2018 sandpiper 389RD me and a friend got it home and it wouldn’t auto level finally got that lined out and now when I put my slides out the jacks raise and when bringing the slides in the front of the 5ver will drop to the ground. Fluid level is good all manually override values are closed no fluid leaking on no jacks or on the ground. I’m lost on what to do next.
Valdez1981 is offline   Reply With Quote
Old 06-23-2019, 07:50 PM   #2
SeaDog's Avatar
Welcome to the forum it a great place to get your questions answered. I don't have an answer for you but I'm sure someone on the forum will. While you are waiting try using the search box at the upper right of the page you may find your answer there.
Just found this in the search something you might try.
Reset/Reboot - The system has no reset button or function, so you have to do it by powering the entire system off then back on. The system has no on/off switch and is connected directly to the battery. There are three ways to cycle power to reset/reboot the system.
On the Leveling Control, locate the 6-pin harness connector that has only one red wire. Unplug this connector from the Leveling Control. Plug the connector back into Leveling Control after the appropriate time has passed.
There is an inline fuse holder on this red wire as well. This fuse may be in a separate compartment from the Leveling Control. The fuse can be pulled from the fuse holder. Return the fuse securely to the fuse holder after the appropriate time has passed.
The motor and inline fuse holder is powered through a 100 amp breaker. Open the breaker to cycle power and close it after the appropriate time has passed.
Any of the above methods will cut 12 VDC power to the system. Be sure to leave the power off for at least 10-20 seconds before restoration.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
