Old 02-26-2012, 08:38 PM   #1
LKicklight's Avatar
Leveling 5'er On a Hill
We currently have our 5'er parked in our driveway that slopes from the street down to the house. I figure it is probably a 4/12 pitch...the nose is up in the air and the rear of course is down in the back..not leveled..
The front legs have been marked for maximum extension and maximum retraction...today I tried leveling it by hooking back to the tow vehicle, putting more blocks under the front legs...made a little difference, but not enough....How can I get the nose down within the limits of the front jacks???
LKicklight
Crusader 270 RET
LKicklight is offline   Reply With Quote
Old 02-26-2012, 08:46 PM   #2
TURBS's Avatar
drive the rear up on blocks wouldn't that help ? then cut a 4x4 angled on the ends to slip in between the tires unless you have something else to lock the wheels ?
Old 02-26-2012, 08:55 PM   #3
LKicklight's Avatar
Leveling
With the rear that high up, I'm affraid of the height it would have to achieve..already have four 6 x 6 chocks along with X-Locks on one wheel..Think I can probably get the front down by putting more blocks under the front jacks and then retracting the jacks accordingly..I think??
Got any more suggestions?
Old 02-26-2012, 08:57 PM   #4
TURBS's Avatar
Dig the driveway out ?
You really don't have many options that I can think of . sorry ?
Old 02-26-2012, 09:14 PM   #5
flyrotor's Avatar
I was expecting a huge slope as 4/12 would normally mean 4 feet elevation in 12 feet distance, such as the roof of a house. I think you meant 4" in 12 feet.
My suggestion would be
1) dig and place concrete where the wheels are going to sit, probably about 4 to 6 inches below the grade,
2) build large blocks for the front jacks that are solid to allow a short extension on your front jacks. The blocks will be more stable than the legs of the jacks.
flyrotor is offline   Reply With Quote
Old 02-26-2012, 09:21 PM   #6
b1b1das's Avatar
Deleted...
b1b1das is offline   Reply With Quote
Old 02-26-2012, 09:46 PM   #7
Crusader's Avatar
LKicklight
Crusader 270 RET
If I am reading this right...it sounds like you have to raise the rear end and lower the front end right ( first paragraph ). If this is so, can you turn the rv around and use the greatest amount of landing gear to level it out? Don't foreget .........chock..chock..chock...
Crusader is offline   Reply With Quote
Old 02-26-2012, 10:12 PM   #8
LKicklight's Avatar
Slope
Yep, more like a foot of slope not 4..my mistake...think if I can block of the front enough to retract the jacks in far enough, and the get them back up to hook back up to the hitch, should be fine...right now I have two cap blocks under each jacking foot, may need to put another one to make it three high..
thanks
