Originally Posted by Chpusmc
Most modern era overpasses are in excess on 14' (well in excess). It is way to easy to become complacent and miss that 13' 6" yellow and black sign.
I've seen a lot where the max clearance is either dead center, where you have to straddle lanes, as the sides are a lot lower.
A few years ago we had a truck knock an Interstate bridge down with his O/S load. Plenty of clearance in the middle, on the sides not so much.
Even at 11' tall with my trailers (old and new) I find that my biggest issue is not the highways but some fuel stops. Get off the beaten path and some still have overhead hazards that are low enough to be a concern.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
