We always disconnect the fresh water hose and drain it for freezing temps. We fill the fresh water tank so we have water for showers/toilet in the morning. I also shut all the gray valves (black is always shut) and make sure the sewer hose is empty. We use a ceramic heater in the bedroom and set the thermostat for the gas heater to come on occasionally to keep the basement heated. If we will be staying for awhile I will use a heated water hose.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
