Old 09-03-2014, 09:14 AM   #1
Low Water Pressure
Most of the parks we stay in have moderate water pressure at best. Any tricks out there in getting better pressure - in particular, the shower? I realize it will never be like home.
TMMason is offline   Reply With Quote
Old 09-03-2014, 09:38 AM   #2
vinmaker's Avatar
Not sure anything can really be done if the flow of water coming into the RV lacks pressure/volume.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-03-2014, 09:38 AM   #3
Paradise has arrived!
Paradise115's Avatar
I replaced the stock showerhead with an oxygenics showerhead. I got it at Amazon. Really made a difference.
Paradise115 is offline   Reply With Quote
Old 09-03-2014, 09:40 AM   #4
Brother Les's Avatar
Always have a pressure regulator on your hose from the campground water supply. Your water line will only take so much pressure as those line also are not 'like the ones at home'. To get better 'pressure' at the shower... try a different show head.....
Brother Les
Old 09-03-2014, 09:51 AM   #5
Thanks for the advice. Think I'll have to check out some different heads. I'd been told before by an RV rep to turn on the water pump even if the tank is empty to boost pressure.
Old 09-03-2014, 09:58 AM   #6
K5bryan's Avatar
Oxygenics shower head is wonderful. Feels like the one at home now!
K5bryan is offline   Reply With Quote
Old 09-03-2014, 10:00 AM   #7
bend302's Avatar
Oxygenics x3
One of the best things I ever did. Couple that with an adjustable pressure regulator set to 50 psi and it is almost like home. Of course, if the campground has low pressure, you can't get more PSI.
Another trick is to use your water pump and onboard water tank for a shower. On my unit, if the incoming pressure is lower than the onboard pump pressure setting, the pump will run and the shower will be better. Of course you need to monitor the fresh water tank to be sure there is enough water for a shower.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 09-03-2014, 10:00 AM   #8
I don't think it's a good idea to run the water pump if you're hooked to city water. At least that's what I've always been told.
Old 09-03-2014, 10:11 AM   #9
imo, leave the water pump off if you are using campground water. Start with better shower head.
Brother Les
Old 09-03-2014, 10:35 AM   #10
mud yapster's Avatar
Unhook your water hose and see how good the pressure is without being hooked to your RV or regulator, if the pressure seems good then maybe your inline filter system (if you have one) is clogged and needs the filter replacing. I have also seen a water pressure regulator malfunction and not let enough water pressure thru. As the others have said though if the parks pressure is low there isn't much you can do.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
pressure, water
