Old 05-07-2019, 08:04 AM   #1
Max Air cover
So...Took my travel trailer in for preventative maintenance. While filling out the order form, they started trying to sell me stuff. One was a Max Air vent cover. They said during high wind storms, there is the possibility of the vent coming loose, so the cover would prevent that. My answer is, going down the road at 60 mph and the vent hasn't came off yet. So I didn't get the cover. What do you think?
2012 Silverado Duramax
2018 Flagstaff 27 RKWS
lbnt18 is offline   Reply With Quote
Old 05-07-2019, 08:09 AM   #2
jeff64's Avatar
I think you should buy one, but not specificly for that reason. I have them on all 3 vents. I think the only time I close the vents is when the AC is running. I even leave the vents open an inch during storage in the off season. Equalizes humidity and the TT doesn't smell and keeps rain out if the vents are open. etc
hint: the black ones or smoke ones absorb heat in the summer! Maxx Air II in white IMHO. I have the black covers for looks, but in summer I have foam plugs to fit in the vent recesses to improve AC performance
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-07-2019, 08:18 AM   #3
MillMitch's Avatar
x2, that was the first thing I added to our TT. Camped a couple times in rain, and put one on myself. My vent stays up 24/7 for all the reasons noted above. I don't have covered storage, so leaving the vent open helps a lot.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 05-07-2019, 08:23 AM   #4
KyDan's Avatar
We have vent covers on both fan/vents for the reasons stated. They allow us to have the vent open even in a pouring rain. Since we occasionally camp off the grid they allow us to have power ventilation any time we want it.
FWIW a vent cover is pretty easy to install if you have no qualms about moving around on the roof it's a pretty easy DIY job. Takes about 15 minutes to install one, less for the 2nd because you're already up there with the tools.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 05-07-2019, 08:41 AM   #5
i added mine before we drove off the dealers lot. For all the reasons stated above, ventilation, ventilation and more ventilation
Another factor, if the vent cover blows off, you have a giant hole in roof of your camper until you replace it
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 05-07-2019, 08:57 AM   #6
bubbles's Avatar
Vent lids are inherently thin and eventually they will deteriorate mainly due to ozone and just fall apart or be destroyed by hail etc.. The vent covers will prevent that.
Old 05-07-2019, 08:58 AM   #7
I agree with all the reasons stated above. Plus the fact that over time the sun will cause the regular vent cover to become brittle and could crack. Installing one is very easy. Kink to installation videos:
https://www.bing.com/search?q=instal...BLH&sp=1&ghc=1
Old 05-07-2019, 09:19 AM   #8
Denver To Yuma In 90 Days
Yup!
Always put them on my campers!
Learned my lesson the hard way after having all three roof vents in my first camper destroyed by hail and the mess that I found inside afterwords.
I had three black vent covers on my 5'ver for looks and to keep light down in the bedroom and living room, but replaced the bathroom vent cover with a white one so that we could get the skylight effect from it.
ID:	203988   Click image for larger version
ID:	203989   Click image for larger version
ID:	203990   Click image for larger version
ID:	203991   Click image for larger version
JohnD10 is offline   Reply With Quote
Old 05-07-2019, 02:51 PM   #9
Putting vent covers on was the first thing I did to the camper. MaxAir vents, I had to have my Travíler head replaced and was told the vent cover was to close. Off came the MaxAir, I still have one vent cover on. I canít tell any difference
spock123 is offline   Reply With Quote
Old 05-07-2019, 02:58 PM   #10
I have the black maxx air covers and black AC covers that came with my motorhome I'm wondering if it's worth either swapping them out for white ones or painting them white. Wonder if it makes a difference with heat at all
KEliasz is offline   Reply With Quote
Old 05-07-2019, 03:01 PM   #11
CincyGus's Avatar
The vent covers that come on the camper are pretty flimsy and after a little time in the sun, get brittle. I've seen more than a few posts about someone that discovered theirs had cracked or had a hole in it when they went to get their camper from storage or after the off season and they were preparing to go camping for the first time that year. Hail, Tree limb, Nuts from tree's, etc.
Some had water damage from it being that way for a while.
The reasons posted above are all legit and reason enough to have them. One that hasn't been mentioned is that I can leave the vents open when traveling down the highway which is a huge help in the hottest parts of the year (or country). You arrive at your campsite with the trailer about 20-30 degrees cooler than you find it if everything is buttoned up tight. The air circulating through the camper makes a huge difference in how long and how hard you AC has to work to get the inside inhabitable.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 05-07-2019, 03:13 PM   #12
Citrus County, Fl.
GL1800Rider's Avatar
I would not be without them for all the reasons everybody has posted already. My dealer installs them at no charge on every new unit that leaves the lot. My previous Flagstaff, I had them thrown in after I agreed to the price and I installed them myself.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 05-07-2019, 03:33 PM   #13
I have one on mine, about $25 and an easy DIY project.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is online now   Reply With Quote
Old 05-07-2019, 03:37 PM   #14
I noticed yesterday that every single new RV at the RV dealership across the street from where I live has vent covers on them.
Probably due to the hot desert sun, I'm sure.
Old 05-08-2019, 03:30 PM   #15
Maxx Air Covers
Maxx Air covers aren't really intended for all that wind speed stuff.
They allow you to open your roof vents even when it's raining out there.
The second benefit is they protect the regular vent lids from high winds, sunlight, all that.
If you like fresh air rather than A/C when it's nice temps outside they make a huge difference. They won't stop a tornado from tipping over your rig.
Kinda like your belt buckle. You could say they can prevent your belly hitting the floor but the real intent was probably to hold your belt together...
Parts Guy is offline   Reply With Quote
cover
