Old 05-14-2018, 03:40 PM   #1
MaxxFan runs on speeds 1 & 4, shuts off on speeds 2 & 3
I have a manual MaxxFan in my 2019 Flagstaff E-Pro. The fan has two buttons, "FAN-ON 1-2-3-4" and "FAN OFF". On our first trip out this past weekend, the fan would only operate normally on speeds 1 and 4. If you pressed the FAN-ON button 2 or 3 times to run at those speeds, the fan would increase to the correct speed, run for 3-5 seconds and then shut off.
I reached out to Maxxair who said they've never seen that before. I'm curious to know if anyone here has experienced that.
Looick is offline   Reply With Quote
Old 05-26-2018, 08:46 PM   #2
Yes, had the same thing happen first time out with our 19 2511s mini lite. Mentioned it to dealer while in for a few minor warranty issues, of course I couldn't recreate the scenario and it has worked fine since. My guess it was the campground electrical service messing with the speed control.
Freetyme is offline   Reply With Quote
Old 05-29-2018, 08:59 AM   #3
After a bit more testing, I'm seeing something similar. When running off batts alone, the fan operates correctly at all speeds. When plugged into any electric service, just speeds 1 and 4 work. I've tested this now at two other campgrounds and plugged in at home, both with and without an EMS.
fan
