Old 01-02-2016, 12:28 AM   #71
Reply to Kenny Kustom
Kenny,
I really do not know. The book with the truck is just the standard Chevy book with the standard Duramax add on. Nothing special from Chevy about what it can tow.
Our Outback is not real heavy, even though it has a frame to take the ATV inside it. It replaced a Keystone triple axle Raptor that was heavier than a dead preacher. I had a 2004 Ford 1 ton 6.0 diesel and the Raptor was really a bit more than I wanted when I had 3 ATV's and gas in the gas station and fuel in the on board generator. I weighed it on the free logging scales here in Oregon but do not remember the exact weight, but it had to be very heavy. That was a heavy unit. The Ford struggled on the grades and sometimes got down to 30-35 MPH with the pedal to the metal. So, I sold the Raptor, sold the Ford, bought the Chevy, and bought the little Outback. Works a lot better.
I would not have tried the Chevy with the Raptor. I would have thought it was too heavy for that gear set.
MacII is offline   Reply With Quote
Old 01-02-2016, 12:38 AM   #72
Reply to Kenny
Kenny,
I just googled the Raptors and the one like ours in the factory specs was 15,900 dry and capacity for another 3,900 in gear and fluids. So, our Raptor could have been around 18-19,000. So, more than twice our Outback, maybe 2.5 times the Outback.
Old 01-02-2016, 01:20 AM   #73
Kenny,
Of course you are right. At first, I was confused at your post because I was thinking 3:73 and it wasn't until I went back and saw I had typed "2.73" instead of "3.73" in the original post like I meant and thought I had typed. My bad. Better proof read better. My truck does not have 2:73 gears, it has 3:73 gears. Still, most of the pickups I have had have been 4:10/4:11 gears and so the 3:73 seemed low to me and the truck was special ordered. Sorry about that. Now I see why you were skeptical.
Old 01-02-2016, 02:23 AM   #74
Kenny kustom's Avatar
Ok!! I thought, man that thing must be a dog !!! ( slow )
Cheers!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-02-2016, 08:21 PM   #75
lckeehne's Avatar
ear, make, and capacity of tow vehicle: 08 Ford Superduty.
Weight of tow vehicle:
Engine and fuel type: diesel
Weight of loaded trailer or fifth wheel: 12,300
Average speed while towing: 55-65
Average terrain (level, hilly, or mountainous 'L,H,M'): h m
Average Miles Per GalloN: 10.9
lckeehne is offline   Reply With Quote
Old 01-02-2016, 08:38 PM   #76
Year, make, and capacity of tow vehicle: 2013 Ford F150 Lariet
Weight of tow vehicle: 7200 GVWR (not sure of actual weight
Engine and fuel type:6cyl ecoboost
Weight of loaded trailer or fifth wheel: Approx 6500
Average speed while towing:60 - 62
Average terrain (level, hilly, or mountainous 'L,H,M'):L & H
Average Miles Per Gallon: 8 - 9
Without towing generally 18-20
I'm a bit envious of the big diesels MPG but $10K will buy a lot of gas.
UltraV is offline   Reply With Quote
Old 01-02-2016, 09:16 PM   #77
Blackhat6mike's Avatar
Year, make, and capacity of tow vehicle:2013 Chevy 2500HD Duramax 2,200lbs
Weight of tow vehicle:7,650 lbs
Engine and fuel type: 6.0 Duramax Diesel/Allison
Weight of loaded trailer or fifth wheel: 10,200 lbs
Average speed while towing: 60-62 Never over 62
Average terrain (level, hilly, or mountainous 'L,H,M'): level
Average Miles Per Gallon: 12-14 mpg depending on wind direction.[calculator@pump]
Without Trailer 18-20 mpg Bullydog Tuner set on performance mode
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 01-02-2016, 10:01 PM   #78
Year, make, and capacity of tow vehicle: 2010 Infiniti QX56, 8900 lbs
Weight of tow vehicle: 6000 lbs
Engine and fuel type: 5.6L V8 (Premium Gas only )
Weight of loaded trailer or fifth wheel: 2016 Rockwood 2503S - 6500 lbs (gross weight, haven't weighed it yet!)
Average speed while towing: 60 mph
Average terrain (level, hilly, or mountainous 'L,H,M'): M
Average Miles Per Gallon: 9.5 - 11 mpg using "Tow Mode"
Average Miles per Gallon not towing - 15 mpg
2016 Rockwood 2503S behind a 2010 Infiniti QX56
Days Camping:
2015 - 7 days
2016 - 12 days
2017 - 4 days (Disneyland!)
CA-2503S is offline   Reply With Quote
Old 05-17-2016, 11:51 AM   #79
wicked1's Avatar
Originally Posted by Jeff95814 View Post
My F250 came with a 26 gallon fuel tank. Not very good when traveling or towing. Reading this site put me onto a 50 gallon replacement aftermarket Titan Fuel Tank. Couldn't be happier.
https://titanfueltanks.com/
Does the Titan fit under the bed like the stock tank or does it go in the bed, I have a 2016 F350 Crew Short Box and would like a tank that doesn't void mfg warranty as mine only has 2300 miles
2016 F350 SCREW SB 6.7 PS Diesel
2015 FR Rockwood Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 05-17-2016, 02:08 PM   #80
5er_tom's Avatar
I think he said it replaced the smaller tank under the truck.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
