Old 10-11-2010, 07:24 AM   #1
Smile Mini lite corner shower idea
We just took possesion of our 2011 mini lite and looking at the shower did not look safe to use because of a great danger of causing a flood between the tub and the sink cabinet. I found a moulding that stick on the base of the shower and the wall and it work perfect and look awsome. It is called seal a crack tub and wall waterproof adhesive sealer and cost less than 6$. I have included a picture. You can cut it to your size and it is easy to remove after in case you change your mind. Avaliable at almost every hardware store
capucine is offline   Reply With Quote
Old 10-11-2010, 09:28 AM   #2
I hope you have better luck w/ the sealer than I've had. I've tried it using it on my tub @ home, but found that it wouldn't stick that well to the top of the tub or walls.
Keep us updated as to how the sealer works.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 10-14-2010, 06:39 PM   #3
Revrnd: I am sure that the reason why it is not sticking well is that you may have some soap residue left on the wall. Also it is very important that you dont touch the sticking mastic with your fingers because it will prevent the moulding to stick properly. This product is working very well because we use it on our rentals units since years and no problems.
Old 10-14-2010, 06:48 PM   #4
Good to hear you've had good luck. As you say, it has to be carefully prepped.
Old 10-14-2010, 07:57 PM   #5
Wish you had posted this before I used bathtub caulk!
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 10-15-2010, 07:15 PM   #6
Emptypocket: I can see that I was not the only one thinking of this problem. I dont think it is too late to remove your caulking later when your camping season is ove and install these moulding. It looks so professionnal and with a roll you can do over 10 showers like the one we have. By the way with what kind of vehicle do you pull your 1809s?. We use our uplander 2009 equipped with a extra transmission cooler and it pulls beatifully. I would not venture in hilly country because I would need a stronger vehicle. I am including a picture of my rig.
Old 10-22-2010, 06:10 PM   #7
We pull our 1809S with a 2004 1/2 ton Chevy with the 5.3 gas. I does have the heavy duty trailer package. It does a great job.
