Old 09-23-2015, 09:56 AM   #31
[Why drive off the big end?
Just pull a bit, remove chock, and roll down. No drama, doesn't go flying... Works great.]
you're right "no drama and works great",......I drilled all the way across, near the top corner of the chocks, so I can slide thru a 1/4" eye bolt 8" long from either side when ready to come off the levelers,.....then clip a pull cord to each eye bolt and wife can stand back away and safely pull them free when I pull the weight off them,......IMO that is a much better and safer way than driving off the big end, even though the company says that is ok
fella10 is online now   Reply With Quote
Old 09-23-2015, 04:24 PM   #32
Wayne Joan's Avatar
I'm still waiting for my promised refund from Andersen. I guess the wheels on my flagstaff are too close together to use as some of you have suggested. Too dangerous and too much trouble for me to use. I'll stick with my boards.
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017
86 days camping 2018
Wayne Joan is offline   Reply With Quote
Old 09-23-2015, 05:02 PM   #33
DaveSchwartz's Avatar
Those of us with close wheels just cut 2" off the thin end of one and smooth it out with a belt sander... works like a charm.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-23-2015, 05:06 PM   #34
Wayne Joan's Avatar
I cut the end off. Now when up on the levlelers the wheels are not at the same level. Didn't look good to me. The one I cut off was caught between the wheels and I couldn't get it out.
Old 09-23-2015, 05:54 PM   #35
MtnGuy's Avatar
I cut the end off of 1 of my levelers, and it is still a tight fit. I am going to take an idea from Old Coot, and do a 45 degree cut on the bottom of the thick side to give a bit more clearance.
I don't really think that having the levelers at different heights makes a big difference. Heck, if I don't need much height, I just use 1 of those puppies anyway.
I got to do something about them sliding in wet grass. I had that happen to me last week. I am thinking about getting some stick-on stair step treads to attach to the bottom of the levelers.
Old 09-23-2015, 07:44 PM   #36
That probably won't help - you'll just end up tearing the grass out of the ground and plowing a huge pile.
If you don't already know this trick, turn off your trailer brakes when you're using the Anderson Levelers. On the Prodigy P2 at least, you do that by holding down the 'boost' button until 'r' appears in the display (you'll probably have to reset your boost option next time you get underway because it will get messed up).
Old 09-23-2015, 09:09 PM   #37
Kenny kustom's Avatar
I read somewhere, to keep a bucket of gravel to make a better base.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-24-2015, 07:21 AM   #38
MtnGuy's Avatar
The trailer brakes shouldn't be functioning while I am trying to accelerate up on the levelers.
That might not be appreciated the next time that area is mowed.
Old 09-29-2015, 02:21 AM   #39
cnmdvm is offline   Reply With Quote
Old 09-29-2015, 07:10 AM   #40
Quit parking in the grass....?
2008 F350 CCSB V10
2016 Sabre 36QBOK
