I looked up MultiSeal and this is on their product page. For the reason below, I would not recommend using them in your motorhome either. Maybe push you off the fence. LOL
Can I use FlatOut™ Tire Sealant by MULTI SEAL® in my passenger vehicle? MULTI SEAL
® does not recommend the use of our products in passenger vehicles or light-duty trucks/SUVs (including ½-ton trucks).
Does our product seal punctures and slow leaks in passenger car tires?
Yes. Is there a chance for high-speed vibration?
Yes. Does this happen in every passenger car tire?
No.
We are conservative in our approach, and we would rather sacrifice some business than have unhappy customers.
You may be asking yourself: Why would there potentially be high-speed vibration in passenger car tires treated with FlatOut™ ? Many factors influence this, such as lighter construction of the tire, lower tire pressure, lighter vehicle weight, lighter construction of the suspension, tire deflection during road impacts and size of tire/road contact patch. In some cases, if the tire is slightly out of balance, the sealant can amplify the problem.
Frankly, we are wary of any tire additive or sealant that recommends use in passenger vehicles. Also, in most cases, the recommended dosage is so small that you do not get effective tire coverage. Plus, don’t be fooled by outrageous claims that a sealant has special ingredients that make it balance tires; the physics of
any liquid at high speed in a passenger car tire are the same.
In addition to potential balance issues, MULTI SEAL
® does not recommend the use of our tire additive with internal Tire Pressure Monitoring Systems (TPMS). While some TPMS sensors in the industrial sector are liquid-friendly, most TPMS sensors in the passenger vehicle market are not. Once again, MULTI SEAL
® is conservative in our approach, and we do not want to risk an unhappy customer.
Beware of sealants that state they are “TPMS Safe,” as this really depends on the type of TPMS and sensors. There is nothing magical that is added to make a sealant “TPMS Safe” … a liquid is a liquid. Be sure to read the fine print.
To learn more, read our blog
here on passenger vehicles and tire sealant.
