We had a similar issue but it was with the black tank where the tank had slipped off of the very in adequate supports that hold the tanks and the discharge pipe had slipped out of its gasket where it enters the tank. Fortunately it was still under warranty at the time and the dealer had to reset the black tank reseal the discharge pipe and they actually put better bracing in to hold the tanks in position. It sounds like you have a similar situation. How we found out about it was I was sitting outside and kept hearing a drip drip drip and look underneath the trailer and saw this water dripping out from where the underbelly covering had a seam I cut a small hole with my pocket knife in the covering and sure and off the whole stream of black water came pouring out.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
