Old 07-06-2011, 07:28 PM   #1
Terier's Avatar
Need help with TV and viewing channels
Let's take one step at a time - lets work on cable stations first.
I was at a cg with cable TV connections. I hooked up a coax cable from the power stand to the coax outlet on the outside of the trailer. Then I had the TV scanned for all available channels. I ended up with only 1 or 2 local stations (KCET & Fox) but a lot of the higher number channels (these stations came in fuzzy).
I tried watching/scanning with the little green on; antenna up and down; set for cable; set for antenna. All of those choices gave me different results but none good.
Question: What are the correct steps when trying to watch TV via cable connection?
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
Old 07-06-2011, 07:42 PM   #2
MtnGuy's Avatar
The booster button off...no little green light. The TV in the cable mode, not antennae mode. I shouldn't matter whether the antennae is up or down, but I would leave it down....something less to forget when you pull-out.
Old 08-07-2011, 01:34 AM   #3
2007 WildCat 32QBBS
18CrewDually's Avatar
I have the same issue. In my case the L/R television isn't digital compatible so I need a converter box to get all the upper channels. Right now i only get about 8 -10 channels.
18CrewDually is offline   Reply With Quote
