Originally Posted by DouglasReid
Whichever brand of tire you select Id recommend going with a higher rated tire than the factory put on. Mine came with E rated tires.
I just needed new tires and went with G rated. Rated for greater weight carrying capacity and a higher speed rating as well.
Just watch out because while the tires will carry a greater weight and give you more headroom on speed, etc., the suspension and axles of your trailer won't carry any more weight than they are rated for. Also, sometimes the wheels will only carry the pressure for the tires they were rated for in the first place and could come apart if too much inflation is applied. Make sure you check the ratings out before inflating the tires to their max. People have been killed by exploding rims.
