03-03-2019, 05:32 PM
Need new tires...best tire brand???
We have a 2014 Forest River Wildwood DBUD Travel Trailer that we need tires on. Plz give us feedback and recommendations for good RV tires. We’re looking at Carlyle, Vanguard, and Hi-Run brands. Any advice is very greatly appreciated!!! Thank you!!!
03-03-2019, 05:37 PM
Maxxis. Goodyear Endurance.
03-03-2019, 05:57 PM
Carlyle's are a good tire.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
03-03-2019, 06:52 PM
Now a "Top Member"
I have the Maxxis tires. They have been very good, though admittedly, I don't have the 5th wheel out quite as much as before. Still, they are good tires. I had Carlisle on my old TT and never had an issue with them either.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
03-03-2019, 07:05 PM
Goodyear Endurance, made in the USA, please don't buy chinese junk tires
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
03-03-2019, 07:19 PM
Goodyear Endurance
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
03-03-2019, 07:23 PM
watching ....
03-03-2019, 07:27 PM
Georgia Rally Coordinator
Originally Posted by allenb12
Goodyear Endurance
X 3 had them now for 2 years and love em. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 62
03-03-2019, 07:41 PM
Carlsie will do well for you . the endurance is supposed to be good also
03-03-2019, 09:46 PM
My Cedar Creek has 215-75/17.5 tires. I can't seem to find any reference to a 17.5" tire. Biggest I see in the Endurance is 16".
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
03-03-2019, 10:29 PM
I think what you have are load range G or H, Endurance only goes to F; There are other Goodyear tires on their website under trailer tires
Danny & Darlene
03-04-2019, 02:19 PM
X2
03-04-2019, 02:35 PM
Retired Member
Went from F rated original to G rated Sailun. So far so good after one year and 5000 miles.
03-04-2019, 02:48 PM
I would allow Carlisle on that list as well. Those ran forever on our old coach with no problems akin to the bad Chinese made "China Bombs".
Big deal for me is to upgrade to Max load range tore you can get. If the plackard on the coach says 50psi cold inflation,. That's a C range tire. I would never have that on a trailer. 65psi is D load range better but not enough. 80 psi cold. Is load range E tires. I run those if they are available in your wheel size. Mine have always been 15 inch and I upgrade everything, TT TH utility trailer or boat trailer to LR . E tires for piece of mind. On lighter trailers I might run less than 80 psi, but I always want those heavyweight guys on the ground.
If you are blessed to have 16 inch rims I think you can go above E but I always upgrade the Load capacity.
On this rig I had myself convinced that with proper tire care and pressure management my load range d China bombs would last a long time. I was wrong. Which brings me to topic number to r tire pressure monitoring system saved us. With a 8-9000 lb travel trailer I won't leave home without it.
Tom48
In Sunny So Cal /w
2004 SD F250 now BULLET PROOFED
2017 Sandstorm 250 TH, with
8 wheel TST TPMS and
The Hot Air Balloon RESTLESS
03-04-2019, 03:30 PM
Upgraded mine from load range c to load range e keeping the same size tire. Went with Goodyear Endurance and love them after two years (going on three). They look great and run great. Because the TT was built for load range c I only inflate the tires to 60 lbs. Dealer said I should do this for wear.
03-04-2019, 03:39 PM
Blog: RVroadtripper.com
SAILUN
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
03-04-2019, 03:44 PM
Michelin, have had failures with every other brand of tire I have had in nearly 70 years of driving, but never a Michelin
Jerry & Sally Martire
Culpeper, VA
2008 FR Flagtstaff 831RLSS
2004 Silverado 2500HD diesel
03-04-2019, 03:45 PM
"Best" ST (Special Trailer) tire brand is debated here every week.
Lots of prior threads. Remember... the OP has a travel trailer.
These always come up on the list of recommended. (in no particular order)
Goodyear Endurance, Maxxis 8008, Carlisle HD.
Days Camped: '16=46 ☼ '17=30 ☼ '18=51 ☼ '19=53
03-04-2019, 04:32 PM
Whichever brand of tire you select Id recommend going with a higher rated tire than the factory put on. Mine came with E rated tires.
I just needed new tires and went with G rated. Rated for greater weight carrying capacity and a higher speed rating as well.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-04-2019, 04:56 PM
It’s time to replace the tires on our fifth wheel,I’m kind of leaning towards the Carlyle HD. Did anyone have any issues with them?
2015 F350 Platinum Powerstroke
2016 Rockwood Ultra Lite
Follow us on Instagram @
Greg.Miranda.Travels
