Old 10-13-2016, 08:17 AM   #21
karrun's Avatar
Wow, some great advice from all of you. Luckily we are not in a hurry so have plenty of time to look. We may even buy gently used if we can find one we really like so someone else would have taken care of the warranty issues and save several thousand dollars.
The RV show idea is great, we bought our Roo from a dealer at the Chicago show.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 10-13-2016, 08:42 AM   #22
Nev
Nev
We have a 2014 Avenger 28rks.This floor plan describes what you are looking for. We bought this for the two of us with room for guests or grandkids.
2010 Dodge Ram 1500 Hemi 5.7
2014 Avenger 28RKS
Nev is offline   Reply With Quote
Old 10-13-2016, 09:04 AM   #23
I'm at 8200 lbs 50 amp 2 AC's and well stocked including 3 cast iron pans. Plus I always keep 5 gal in the black water tank. Although I can't swear it was in there while on scales, that's only 40 lbs difference. That why I suggested it.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 12-31-2016, 09:34 PM   #24
Tapex's Avatar
Originally Posted by karrun View Post
Man, am I confused. I know what i want, but there is so much to choose from. I was hoping someone could at least steer me in the right direction
BTW, this isn't happening until next year at the earliest. We just bought our rockwood Roo last May, and DH will hit the roof if I talk about buying another already. But I thought I could at least start looking.
We have an low mileage Excursion (tow capacity 9200 lb) that we love so definitely TT vs 5er. I'd like to stay with GVWR of around 7500-8000 lbs so we are comfortable pulling through mountains. It's just the two of us, so only need one bed with a pullout couch for the occasional guest. I'd like two recliners, a couch, lots of floor space and storage space, so at least one big slide, island kitchen (hopefully) and free standing kitchen table. Outdoor kitchen isn't a must. Don't need a tub.
We haven't had a bit of trouble with our Roo, so we are spoiled and would rather stay away from the "value" line of TT, if there is such a thing. Oh, and this most likely will be our retirement TT (she says now) so I would like to be very happy with it.
I've probably forgotten other must-haves.
Any suggestions on what line to start looking at?
Check out the Coachmen APEX Ultra Light with AZDEL! Awesome product for construction!
2016 Coachmen Apex 250RLS Ultra Light
2023 Ram 2500 Big Horn Sport 3.73
Tapex is offline   Reply With Quote
Old 01-01-2017, 05:59 AM   #25
Sounds like you just described a new 272rl.
We love ours.
D-Man is offline   Reply With Quote
Old 01-01-2017, 06:52 AM   #26
Although Azdel is better, its not a miracle material by any sense of the word for a laminated wall. It's still the same adhesive used and the same lamination procedure. The Azdel is only used for the outer substrate layer behind the Filon, between it and the foam. You still have Luan plywood for the inner panel that the wall covering is applied to. Introduce water into the assembly and you can still get delam from the Azdel releasing from the foam, or the luan releasing from the foam, or the Filon releasing from the Azdel. Granted the Azdel will not delaminate itself, like the plys in Luan plywood can when it gets wet, but it does not really matter because if you get water in there, something else will come apart. To me its more of a marketing gimmick than anything and they can use the "green" claim in advertising as its a recycled product. Some manufacturers, Jayco is one, Heartland is another, used Azdel for awhile and went back to Luan. The claim is the Luan plywood takes to the adhesives used better than the Azdel as its more porous.
The use of Azdel would not sway me one way or the other on a laminated trailer.
Mr Havercamp is offline   Reply With Quote
Old 01-01-2017, 08:00 AM   #27
Nev
Nev
What you described as floor plan is almost identical to a Primetime Avenger 28rks. Have 2014 model,exactly what we were looking for.
2014 Avenger 28RKS
Old 01-01-2017, 08:12 AM   #28
Zak1's Avatar
If it's just the two of you most of the time, We bought a "couples trailer"
that we love. We looked for over a year for something we liked. Take a look at the V-Lite 30WIKSS. Three slides, huge forward bathroom with two sinks...
Zak1 is offline   Reply With Quote
Old 01-01-2017, 08:46 AM   #29
Tapex's Avatar
Very interesting and informative post! Thanks for sharing your experience in knowing how these RVs are constructed Mr Havercamp!
Old 01-01-2017, 08:48 AM   #30
Tapex's Avatar
Yes this is the floor plan that seems to be a great RV for only me and DW!
Old 01-01-2017, 09:26 AM   #31
Another thing I have noticed with Azdel is over time the seams between panels are not as noticeable through the fiberglass as they become with a luan based wall. You can still see them when looking down the wall at a slight angle but it just seems to me the Azdel backed are not as noticable. If I was going to say there is a true benefit, that would be it. Not a deal breaker as you can see those seams on any laminated panel.
Old 01-09-2017, 05:09 PM   #32
Broken Toe
Cowracer's Avatar
Originally Posted by rockjohn View Post
Rockwood 8329SS.
X2. They look so bad-ass sitting behind a fine Excursion. But then again, I might be biased.
What engine do you have in that Exy?
The V8 gas maxes out at 7600 (2wd with 4.10 gears)
v10 maxes out at 11000 with the 4.10 gears (4x4 or 4x2) and
10,000 4x2 or 9600 4x4.
The 6.0 diesel is good for 11k in both 2 and 4wd.
There is no combo that has a 9200 weight limit.
http://www.fleet.ford.com/resources/...wing_Guide.pdf Page 21
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 01-09-2017, 06:17 PM   #33
karrun's Avatar
Yes, you're correct. We have the V-10 4x4 with 3.73 axle.9600 lbs, not 9200. And yes, I do agree, that Rockwood 8329SS would look badass behind the Ex.
We love our Roo, really happy with the quality, so I would be inclined to stay with Rockwood.
But I don't know, 7900 lbs seems a bit heavy?
2016 Roo 21SS
Mods so far:
Old 01-09-2017, 06:29 PM   #34
GVWR of the 8329SS is more like 9662 lbs. Don't go by dry weight.
Rockwood Signature Ultra Lite Fifth Wheels / Travel Trailers by Forest River RV
2011 Traverse LT, 3.6L, FWD
Old 01-09-2017, 07:38 PM   #35
Broken Toe
Cowracer's Avatar
Nah. Even at the max load of the trailer, your are right at the max trailer rating of the Exy. If they didnt want you to tow 9600, theyd have said so. Axles and brakes are the same as a diesel Extra, so there's still some cushion there. That thing'll yank a 8329ss safely down the road at 65 in about 90% of the roads.
Tim
"Camper" 2016
Old 01-09-2017, 08:53 PM   #36
karrun's Avatar
Tim
Yeah, 90%, that's the thing. I want to be able to travel out west through mountains. Don't want to be stressing that we are going to blow the transmission while doing it.
2016 Roo 21SS
Mods so far:
Old 01-09-2017, 10:23 PM   #37
Broken Toe
Cowracer's Avatar
IIRC the v10 has the 4r100 trans (same as the diesels). By 2005 they had the big coolers on 'em. I burnt mine (2002) up, had a bulletproof one built and now I have the 6.0 cooler on it. I never get more than 100 over ambient.
I understand your concern, but I personally think its unfounded. Other than the actual motor, you have the same equipment as a 11000 rated diesel, and you are still staying within max weight.
The Rockwood 2703ws is the little brother to the 8329ss. Weighs out at about 7800 gross. That might be a good option for you.
Tim
"Camper" 2016
upgrade
