Old 12-30-2013, 12:41 PM   #11
JoeMazz's Avatar
Originally Posted by sidney View Post
What models were effected?
The weights on our 5er have not changed.
Previous post by French laid them out in detail. My 8282ws pin weight up 140 lbs
Sent from my DROID RAZR HD using Forest River Forums mobile app
2015 Jayco Precept 35UP
JoeMazz is offline   Reply With Quote
Old 12-30-2013, 12:53 PM   #12
Oakman's Avatar
How about a link to that post? The Cedar Creek and Silverback line haven't changed that I can see.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 12-30-2013, 01:07 PM   #13
Fulltime family RVer
Here it is:
Originally Posted by French View Post
Rockwood
pin weight Fivers as per 2014
Almost every unit has changed the heaviest pin now 1492 it was 1600 last year!
Model 8244
was 1288
now 1181
change -107
-8.31%
Model 8265
was 1159
now 1287
change 128
11.04%
Model 8280
was 1046
now 1089
change 43
4.11%
Model 8281
was 1600
now 1428
change -172
-10.75%
Model 8282
was 1184
now 1324
change 140
11.82%
Model 8285
was 1146
now 1146
change 0
0.00%
Model8286
was 1411
now 1447
change 36
2.55%
Model8288
was 1487
now 1492
change 5
0.34%
Model 8289
was 1524
now 1337
change -187
-12.27%
8282WS Diamond Package
ependydad is online now   Reply With Quote
Old 12-30-2013, 01:11 PM   #14
Oakman's Avatar
Thanks ependydad, I guess the changes aren't across the board at FR but just a couple of their brands.
Bob and Joyce
ATU Local 788
Old 12-30-2013, 01:26 PM   #15
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
We are ordering a 2014 Wildcat 282RKX in 3 weeks (January 2014). When visiting the Wildcat factory this past fall they were in the process of changing over to Norco Ind. Bal Frames.
Not sure on which models the new frames will be used on, but the 282RKX was getting the new frame. 2013 brochure states hitch weight of 1,280, website now states the 2014 282RKX has a hitch weight of 1,385. Also dry weight is up about 400lbs.
Cover Dog is offline   Reply With Quote
Old 12-30-2013, 01:58 PM   #16
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I checked the differences between the published 2013 Surveyor SVF293 fifth wheel and the 2014 unit. The pin weight was 111 lbs heavier and the real surprise was the height w/AC increased by 1'1". That's quite a change. It looks like the differences might be a different frame as noted earlier. Did anyone who noted an increase in pin weight note a change in height too?
2013 pin weight = 1681 lbs 2013 Height w/AC = 11'6"
2014 pin weight = 1792 lbs 2014 Height w/AC = 12'7"
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 01-09-2014, 05:16 PM   #17
JoeMazz's Avatar
Just got an official, unofficial answer from FR on the 8282ws.
140lb increase in pin weight and 400lb increase in total weight are the result of moving the axles forward and beefing up the frame for reasons including, but not limited to, the 2 opposing slides on this particular model.
Was also told that based on my VIN, my 2014 and most likely all the 2014's are of the new, heavier 8282ws.
Old 01-10-2014, 09:59 AM   #18
Interesting. I wonder if that holds true for the entire Rockwood/Flagstaff 2014 lineup.?
Mtelkman is offline   Reply With Quote
weight
