Old 10-18-2007, 02:19 PM   #31
Rockinwood's Avatar
Originally Posted by 2008Wildcat View Post
The best way to eliminate sway is to buy a fifth wheel.
Yea true, but that would eliminate my Excursion Not going to do that esp with 3 kids their friends and the dog
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 10-19-2007, 06:55 AM   #32
You could get a "hitch buddy". I've looked at their website and it looks like it could work. Haven't read any testimonials though.
Paul B
2001 Excursion PSD
2000 CRV Honda
2006 829GRSS Flagstaff TT
2004 Twin 2000i Hondas'
Paul B is offline   Reply With Quote
Old 10-19-2007, 05:57 PM   #33
Rockinwood's Avatar
Its all good, dont need to spend anymore money. Happy with what I have.
Old 11-06-2007, 05:30 AM   #34
For the first time camper, we depend on the dealer to sell us the proper equipment to tow with and the service dept to install it correctly. For the Veterans of camping, they have had the experience with most of the equipment that is used and know of other solutions. Under this thread, I am refuring to page #3 under " IT'S HOME " by Cbduece. A manual was posted by NDJOLLYMON about the REESE dual cam sway control, I suggest that if anyone has this type of hitch and you do not have a manual it would be good to print it out, I did and guess what? I found 6 different thing wrong with the instulation. I started camping in 2000 and had the same hitch and never Had a problem for 5 years. In 2005 I step up to the the ROCKWOOD 8314ss. My camper was back to the dealers two times for hitch problems, this is the dealer I bought my first camper from in 2000 " very happy at that time thats why I went back! Any way, I have posted pic on what I have found. I color coded the problem areas to pin point my findings. pic #1. shows all the problems. pic #2. RED shows the U- bolt in the wrong direction and the chain on the wrong side. pic #3. GREEN the cam arm yoke is adjusted too far out. pic#4. BLUE frame plate is in the optional position instead of the preferred position, there is nothing in the way to set it up this way. pic. #5 shows uneven wear on the cam arm. think this is caused by the chain being on the wrong side of the hanger bracket. I have two more pic to post.
Old 11-06-2007, 05:45 AM   #35
pic. # 6 YELLOW the snap-up bracket is not streight up, it is angeled more to the right that means the sping bar is not in the right position. pic. # 7ORANGE shows the distance from the center of the hitch ball to the frame plate, the manual says 18 inchs, mine is 17.5inchs.
Name:	hight yellow.JPG
ID:	495   Click image for larger version
Name:	hitch orange.JPG
Old 11-06-2007, 05:53 AM   #36
Reese Dual Cam High-performance Sway Control
ID:	497   Click image for larger version
ID:	498   Click image for larger version
Name:	hitch green.JPG
ID:	499   Click image for larger version
ID:	500   Click image for larger version
Old 11-06-2007, 12:16 PM   #37
Commercial Member
huntr70's Avatar
Don't really think any of those things will affect how it works to eliminate sway.
Your cam lobe isn't worn any more than mine was after a year.
.5 inch off on the bracket is nothing since there is plenty of arm adjustment.
The u bolt can face in or out, not going to affect anything.
The set up itself may need some tweaking to give you better sway control.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 11-06-2007, 06:36 PM   #38
jmyers's Avatar
rockwood06, I notice your chain has 11 links... mine has 9. Just curious. I want to run with 3 hanging but I still don't have mine set up right. I'll work on it this winter so maybe next spring I'll feel more comfortable with it. I won't go into details, as I'm sure everybody is sick of hearing hitch problems. I know I am. And I'm one that has 'em.
My driver's license says my name is "Jeff"
2000 Chevy 2500 4/4 6.0/3.73
2002 FR Sandpiper 30FKSS
Reese Strait-Line
Prodigy
DW
DD (Darling Dachshund)
jmyers is offline   Reply With Quote
Old 11-07-2007, 04:14 AM   #39
Thanks to those who replied for your input.
Old 11-07-2007, 08:32 AM   #40
Dodge Guy's Avatar
The U-bolt do indeed need to be on the inside of the hanger plate! the nuts to the outside. everything else is OK. the wear on the cam arm is normal and will seat over time. BTW make sure to always keep the WD bars on the same side. this will keep the wear in the arm to a minimum. with the DC it doesn`t matter if the snap up bracket is to the front or the rear of the plate. the chain no longer moves as on a standard WD hitch.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
