11-04-2019, 05:04 PM
Outdoor storage level question.
This may be a silly question, but when I store the camper outdoors for the winter, should I level it or leave it slightly high in the front? not sure if it matters but figured I would ask.
11-04-2019, 05:13 PM
Always Learning
We always kept ours a little nose high to keep the run off going where we wanted it to. But really, no big deal either way.
11-04-2019, 05:31 PM
Kasual Kamper
I tip mine at about a 7-9 degree angle toward the rear so any accumulated snow and ice has a chance to run off on warmer days.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
11-04-2019, 05:42 PM
NH Maple Maker
I store mine nose down for no particular reason.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
11-04-2019, 05:55 PM
Since you have a Rockwood, do you have torsion axles? If so, store it parallel to the slope of the ground fore and aft so that the suspension has the same pressure on each set of axles.
11-05-2019, 01:46 PM
I have torsion axles on mine and still store with a 3-5 degree tilt to the rear. I don't think this small pitch will have much of any affect on the axles.
I picked rear because I leave my roof vents open a crack for ventilation - I do have Maxxair covers over both vents and they have the openings pointing back.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
11-05-2019, 01:59 PM
Personal preference I think.
I like to store it either nose down or up just to allow some run off.
For those that may go out and sleep a night or two in it may want it more level
11-05-2019, 02:03 PM
All you have to do is to have the front set of tires on top of a piece of wood to level out the suspension.
11-05-2019, 04:47 PM
Storage
I store w/ slight tilt to the rear w/ torsion axles, maybe 3%. Since my lot slopes to the back already this just makes it where I run my jack less.
11-05-2019, 04:51 PM
Storage
More important than the slope, I put leveling plastic gridlwork leveling blocks under the tires. The kind that have a waffle pattern and holes in the blocks. Gets the tire off the ground and rocks.
11-05-2019, 08:07 PM
Ham Call N8SAC
Store mine with front slightly higher than rear. I park mine in back yard . Leave power hooked up . Park on wood 2X8X10” to keep off ground. But is on gravel.
11-05-2019, 08:38 PM
More important
Front sightly up to allow rain to move backwards, but most important, check gutter seams and roof caulk at back of trailer where water will run. Check all seams and caulk as snow will hold water there for extended periods if you live in a snow region.
11-05-2019, 09:24 PM
I tilt mine with front up for rain drainage. I don't want to drain towards front cap.
Chuck& Shar
2018 2715VS
11-05-2019, 09:28 PM
I don't think it matters unless it is very unlevel.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
11-05-2019, 09:35 PM
personal preference. roof is sloped so water runs off level or not
