Old 04-07-2014, 06:31 PM   #1
eileent's Avatar
Oven won't light
Out on the 1st trip of 2014 and my oven won't light. Stove works, HW tank lit, fridge working on LP. I'm sure a spider is clogging the line. How can I clean it out ? Need to make biscuits in 2days !
eileent is offline   Reply With Quote
Old 04-19-2014, 06:50 AM   #2
eileent's Avatar
Wow, can't believe no one could help me..... I used to get answers here all the time.
Old 04-19-2014, 07:03 AM   #3
shadow7663's Avatar
Did you try to light the pilot with one of those long lighters? If the pilot will light off another flame source most likely the spark ignitor for the oven is bad.
2014 PrimeTime Avenger 33BHS
2005 Dodge Ram 2500 4x4 Quad Cab 5.9 Cummins
12k Equal-I-zer hitch
shadow7663 is offline   Reply With Quote
Old 04-19-2014, 07:21 AM   #4
eileent's Avatar
Hey thanks, but I believe I must have an occlusion somewhere because the pilot and the actual oven burner are NOT getting LP. I need to take it apart and blow compressed air thru it.
Old 04-19-2014, 07:24 AM   #5
dmf564's Avatar
OK here goes, not sure what your doing or not doing so step by step here we go.
1. Gas is on, turn oven to start or Pilot.
2. Press down on the knob.
3. With a long lighter hold a flame at the end of the pilot flame tube. If it seems to take a min. You can see (with a flash light) the metal rod that is also a heat sensor for the gas shut off. Hold the lighter on the metal rod for a min, until you see it glow then turn the stove on regular ( pick a temp) then the burner should light. If you have spiders in the line the heat from the burner will run the out and they will die.
Try this and see how it goes.
Sent from my DROID BIONIC using Forest River Forums mobile app
[SIGPIC]TV-2012 Ford F250 XLT Supercrew 4X4
TT- 2010 Jayco Jay Flight 17Z (traded)
TT- 2012 Coachman Catalina 30BHS (current)
Me and my wife with 3 kids love camping!!
dmf564 is offline   Reply With Quote
Old 04-19-2014, 07:25 AM   #6
fonzie's Avatar
Once you set to pilot, do you push on knob for one minute and try to light pilot inside oven?
Fonzie
Old 04-19-2014, 07:27 AM   #7
eileent's Avatar
Thanks everyone, posted this 2wks ago while camping, fiver now back in storage. In 30 yrs of camping never had this happen in any of my RV's
Old 04-19-2014, 07:29 AM   #8
dmf564's Avatar
The burner won't receive any gas until the little heat sensor is hot. Its a safety gas shut off sensor.
Old 04-19-2014, 07:31 AM   #9
dmf564's Avatar
Sorry Eileent
Didn't see the post.
I hope the info above helps on your next trip
Old 04-19-2014, 07:33 AM   #10
eileent's Avatar
Thanks, dmf...... when it comes home again I will try
light
