Old 09-23-2018, 05:26 PM   #1
swampdonkey772's Avatar
Overhang flaking
So I just bought a 2014 Coachmen Chaparral 29bhs. Brought it home and going over it I noticed that where the bottom of the overhang meets the sidewall it is flaking. I did notice the silicone right above this spot was seperated from the trim. Could this be water intrusion? See attached pics as I probably have not explained this very well.Click image for larger version
ID:	187355Click image for larger version
ID:	187356Click image for larger version
ID:	187357Click image for larger version
ID:	187358Click image for larger version
ID:	187359Click image for larger version
ID:	187360Click image for larger version
ID:	187361Click image for larger version
swampdonkey772 is offline   Reply With Quote
Old 09-23-2018, 05:28 PM   #2
mbbutler's Avatar
If not it will be.
mbbutler is offline   Reply With Quote
Old 09-23-2018, 05:33 PM   #3
FordHauler's Avatar
When the manufacturer paints caulking, in a short while it will crack. The sealer can move and flex but the paint cannot.
If you reseal these areas DO NOT use silicone, it has no place on an RV.
Research auto paint and bodywork sites for the correct sealant.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
98 gallons of diesel on board! GVWR 14,000 LB.
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
FordHauler is offline   Reply With Quote
Old 09-23-2018, 05:43 PM   #4
Mbbutler what do you mean by your statement? Is this just mainly cosmetic? Do I need to teseal the underside of the overhang by pulling the trim back and resealing it?
Old 09-25-2018, 02:46 PM   #5
Travel safe
Sorry for the delayed response. You thinking is just painted caulking? If it is that will make things super easy to correct. What would you suggest to do about resealing the trim edges?
