Old 12-13-2018, 11:04 AM   #1
Pin box bolt torque
I want to adjust my pin box down so I can lower the ball on my Andersen Ultimate. The bolts are most likely 5/8", as the bolt heads are 15/16". Does anyone know for sure what the proper torque is for them? I've searched the net and the forum, and haven't found a conclusive answer. (I have 7" of clearance between the bed rails and the 5er so that's not a concern.) Thanks!
David and Vicki
8 year old Springer rescue Sydney
2018 Silverado LTZ 3500HD Dually Crew Cab Duramax/Allison stock "Polar Bear"
2019 Grand Design Reflection 337RLS "The Dog House II"
Andersen Ultimate 5th wheel hitch
EezTire TPMS
Springerdad is online now   Reply With Quote
Old 12-13-2018, 11:16 AM   #2
This is what was on Etrailer, I will say this I tried 275lbs on 3/4 #5 bolts and lock washers, it broke my lock washers. I also had an RV tech tell me 120lbs, they use air impact wrenches set to 120 ft lbs. I went with 225 ft lbs using Grade 5 3/4 bolts, I check mine twice a year.
1/2 inch Bolts GR5 90 ft-lbs
5/8 inch Bolts GR5 150 ft-lbs
3/4 inch Bolts GR5 275 ft-lbs
Here is the link - https://www.etrailer.com/question-138310.html
Here is another link - http://americanboltcorp.com/tech/techtorque.pdf
wildcatter is online now   Reply With Quote
Old 12-13-2018, 11:23 AM   #3
Head Rambler
Do you know which pin box you have.
Here's what etrailer says about the 1621 pin box torque specs.
Pin box bolt torque is based on the size of the bolts.
Gotta go campin!
Old 12-13-2018, 12:49 PM   #4
Thanks. That was the number I came up with based on size. Just wasn't sure what Lippert wanted.
David and Vicki
EezTire TPMS
Old 12-13-2018, 01:11 PM   #5
Gsykora's Avatar
That's a big torque wrench to get to 275ft/lbs.
George & Nancy, Allen, Texas
2015 F350 CC, DRW, LB, Platinum Edition
2018 Cedar Creek 36CK2
Gsykora is offline   Reply With Quote
Old 12-13-2018, 01:52 PM   #6
Here are recommended torque specs for bolts from a manufacturer.
Size Recommended Torque
Grade 2 Grade 5 Grade 8 18-8 S/S Bronze Brass
Coarse Fine Coarse Fine Coarse Fine Coarse Fine Coarse Fine Coarse Fine
#4* - - - - - - 5.2 - 4.8 - 4.3 -
#6* - - - - - - 9.6 - 8.9 - 7.9 -
#8* - - - - - - 19.8 - 18.4 - 16.2 -
#10* - - - - - - 22.8 31.7 21.2 29.3 18.6 25.9
1/4" 4 4.7 6.3 7.3 9 10 6.3 7.8 5.7 7.3 5.1 6.4
5/16" 8 9 13 14 18 20 11 11.8 10.3 10.9 8.9 9.7
3/8" 15 17 23 26 33 37 20 22 18 20 16 18
7/16" 24 27 37 41 52 58 31 33 29 31 26 27
1/2" 37 41 57 64 80 90 43 45 40 42 35 37
9/16" 53 59 82 91 115 129 57 63 53 58 47 51
5/8" 73 83 112 128 159 180 93 104 86 96 76 85
3/4" 125 138 200 223 282 315 128 124 104 102 118 115
7/8" 129 144 322 355 454 501 194 193 178 178 159 158
1" 188 210 483 541 682 764 287 289 265 240 235 212
* Sizes from #4 to #10 are in lb-in.
Sizes from 1/4" up are in lb-ft.
Fine thread figures are for 1"-14.
Grade 2, 5, and 8 values are for slightly lubricated bolts.
EDIT: That formatting made it a little hard to read.
Here's a pic...
Name:	bolt torque specs.jpg
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 12-13-2018, 03:13 PM   #7
I've got one. Seriously. 1" drive. Sombitch is three and a half feet long. Goes up to 500 ft lbs. Ya need two men, a boy, and a donkey to carry it.
David and Vicki
EezTire TPMS
