Old 08-30-2019, 09:41 PM   #1
Dannimal's Avatar
Pin box mount modification
My 5th wheel runs about 3.5" nose high. I have a sidewinder and I can't raise it higher on the mounting bracket without interfering with its operation. Does anyone know if it would be a problem to cut about 1.75" off the bottom of the mount? I can't see a problem with it but I may be missing something. In the photo I would cut below the blue tape. BTW the springs are on top of the axle, springs are mounted in the bottom hole of the brackets, I have 7" bed clearance and hitch is as low as it goes. Thanks for any advice.
2011 Sabre 29CKDS
2016 Ram 6.7 diesel
Dannimal is offline   Reply With Quote
Old 08-31-2019, 11:25 AM   #2
Dannimal's Avatar
Somehow picture turned sideways, the trailer wasn't that way when I took it!
2011 Sabre 29CKDS
2016 Ram 6.7 diesel
cat, mount
