Old 02-14-2015, 12:13 PM   #11
Are we there yet.......
Pbalmer65's Avatar
Reviewed line and all good.
Any camping will do. :-)
Pbalmer65 is offline   Reply With Quote
Old 02-14-2015, 12:30 PM   #12
So you now have propane flowing? Youroo!!
Old 02-14-2015, 12:33 PM   #13
Pbalmer65's Avatar
Propane issue HELP!!
Sorry!!! No propane still. :-(
Any camping will do. :-) no kinked hoses that is.
Old 02-14-2015, 12:38 PM   #14
fonzie's Avatar
Well then start at your propane bottles, disconnect them (both bottles) and make sure no obstruction. Re-connect and make sure connection is tight so propane bottle security valve gets open, open both propane tanks very very slowly. Go to your stove and purge propane until it lights. If that doesn't work then probably a faulty regulator.....also can tap regulator gently in case in got stuck when trying to switch over??
Looking at the inside of an OPD equipped propane cylinder valve
OPD Valve Design
The design of the OPD valve is such that turning the cylinder service valve handwheel will not produce any effect if the cylinder is not hooked up to an appliance. In other words, a connection must be made between the appliance hose end and the cylinders service valve. The inside of the OPD valve is engineered to only allow propane in or out if the internal valve is actuated by being depressed. This OPD valve feature adds additional safety in case the handwheel is turned, opening the valve. For this reason, OPD equipped cylinders will not allow gas out of the cylinder when opened. The same is true for industrial forklift cylinders. Click the photo of the OPD valve (left) to see a larger and more detailed picture of the of the internal flow valve.
See additional OPD Valve Information
http://www.propane101.com/valveopennopropane.htm
Fonzie
Old 02-14-2015, 01:32 PM   #15
Pbalmer65's Avatar
After going over all suggestions I'm still without propane. I found that I have a Quick connect just about 2 foot from the regulator under the trailer. There is nothing from the regulator to this Quick connect. With both gas bottles on I used a small screwdriver and pushed in the center spring valve and has no gas at that point as well. :-(
Old 02-14-2015, 01:36 PM   #16
VinceU's Avatar
seems like regulator is NG!
Old 02-14-2015, 01:43 PM   #17
caper's Avatar
This might sound like a stupid question but are you certain that the person filled the tanks actually fill the tanks? If they do not do it properly valve can freeze not allowing LP into tank. What is the outside temp.? At low temp. propane will not flow properly.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-14-2015, 01:48 PM   #18
Pbalmer65's Avatar
Well after a very cold night last night and a trip to RV parts house to get one of these. I'm happy to say I now have propane throughout. :-). Why is not to ask just greatful for the help from my friends on the forum. THANK YOU!!!! Click image for larger version
Name:	ImageUploadedByForest River Forums1423943213.536555.jpg
Old 02-14-2015, 01:50 PM   #19
Flybob's Avatar
Turn off both tanks. Disconnect one completely then reconnect it. Wait 5 mins Now turn on the disconnected tank very slowly 1/4 turn wait a minute then open slowly. There is a open valve protection mechanism in the tank. When it senses a sudden high flow rate, it shuts off the gas. It takes a while to reset. Since you ran out, the lines in the trailer were empty and when you turned on the gas, it had no back pressure so the protection mechanism thought you had an open valve. The first 1/4 turn when you open it is most critical. Y
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-14-2015, 03:20 PM   #20
fonzie's Avatar
Well after a very cold night last night and a trip to RV parts house to get one of these. I'm happy to say I now have propane throughout. :-). Why is not to ask just greatful for the help from my friends on the forum. THANK YOU!!!! Attachment 69633
Glad that it's fixed....
Fonzie
propane
