Old 02-14-2015, 11:04 AM   #1
Are we there yet.......
Pbalmer65's Avatar
Propane issue HELP!!
I'm out camping and lost heat stove fig and hot water. Tanks are full. Please advise. :-(
Pbalmer65 is offline   Reply With Quote
Old 02-14-2015, 11:08 AM   #2
wmtire's Avatar
Simple thing first, are both valves on the tanks open so the auto changeover can occur if one cylinder did run out of fuel.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-14-2015, 11:14 AM   #3
Pbalmer65's Avatar
Both tanks are full and valve at regulator is parked to the tank that is with the regulator.
Any camping will do. :-)
Old 02-14-2015, 11:17 AM   #4
caper's Avatar
Have you tried turning off the gas and opening the valve slowly?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-14-2015, 11:19 AM   #5
Pbalmer65's Avatar
Yes
Old 02-14-2015, 11:20 AM   #6
Flybob's Avatar
What did you do with propane system just prior to your issue? Change tank, fill tank, just turned on for first time. What is outside temp?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-14-2015, 11:22 AM   #7
Pbalmer65's Avatar
Ran out of gas. Refilled returned reinstalled and can't get a green gauge indicator on regulator.
Old 02-14-2015, 11:36 AM   #8
Evereddie's Avatar
Try this again. Turn off both tanks. Then turn on the stove for a minute. Move the switchover valve to the other tank. Turn off the stove. Very ,very slowly turn back on the active tank only (the one that the switchover is activated for).
Evereddie is offline   Reply With Quote
Old 02-14-2015, 11:44 AM   #9
Pbalmer65's Avatar
I tried just that to no avail. :-(. Still. Red indicator. Please note. I have a stand by regulator if needed.
Old 02-14-2015, 12:11 PM   #10
Check to see if the propane tank line is pinched behind tank. This may have occurred while installing tank.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
propane
