GandBL,
Why is there a differences in the placement of the Propane tanks before and after WD installation?
Did the dealer move the Propane tanks to install the WD hitch brackets?
Do you have the
Equal-i-zer brand WD hitch, or something different?
I have the
Equal-i-zer brand WD hitch and have no problem with the Propane cover rubbing the front of the TT. The "L" brackets do contact the tank cover but only slightly.
Here's a picture of my set-up.
Would it be possible to move the Propane tanks to the front of the tongue, just behind the jack?
If so, you could install two batteries between the Propane tanks and the front of the TT. That would put your Propane tanks ahead of your WD spring bar brackets.
HERE is a link to
Modifying battery tray .
HERE is another.
Click on the links below.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/17077022/gotomsg/17079346.cfm#17079346
http://good-times.webshots.com/photo...79378386uYrbnO
http://www.rv.net/forum/index.cfm/fu...d/17482193.cfm
