Old 03-22-2019, 05:01 PM   #1
Puma power
Hello all I have a 2019 puma 32RBFQ, i did not get the washer and dryer or the second air conditioning unit. my question is the plug for the travel trailer is a 50amp but I’m assuming it’s really like my last travel trailer ( wildwood 36 BHBS) which was a 30 amp and I was able to run the trailer on a 20amp breaker, no a/c. Would like to run my new trailer with the same breaker Any thoughts?
speedzone9 is offline   Reply With Quote
Old 03-22-2019, 05:07 PM   #2
Flybob's Avatar
You will need a 30A to 50A adapter then you can use the same adapter you used for your 30A unit. You will probably eventually need the 30A to 50A adapter anyway. As you are aware, you will have the same limitations as to what you can run as before.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
power, puma
