Old 05-02-2016, 10:35 AM   #1
Question about leveling
Hey all, I think I have decided on going with the Anderson leveler system and just wanting to make sure that leveling with 1 tire/axle is ok or is it preferred to level with both tires? I would rather not buy 2 levelers but if it tweaks the axles or suspension in a bad way using only 1 then I will get 2.
Eric
2016 Palomino Solaire GT3 315RLTSEK
2005 Dodge 2500 Cummins
Ewehrum is offline   Reply With Quote
Old 05-02-2016, 12:29 PM   #2
mekkerlc's Avatar
We went with the Andersen as well.
Got two of them, as I don't see a way to level correctly without both axles.
Haven't used them just yet...fingers crossed they are big enough for those VERY un-level sites!
Luke & Carolyn
2012 Cedar Creek Silverback 35QB4
2013 Sierra 3500HD Duramax CC SRW SB 4x4
Andersen Ultimate Aluminum 2 Gooseneck Mount
mekkerlc is offline   Reply With Quote
Old 05-02-2016, 12:49 PM   #3
Always Learning
Level both.
Old 05-02-2016, 12:53 PM   #4
Level both.
Like this "Level and Chock" at the same time! Youroo!!
Old 05-03-2016, 07:41 PM   #5
I have 2 sets of the andersons and love them. My wife gets in the drivers seat after I back in and puts the truck in 4 LO. I place the levelers on the low side and she creeps the trailer up on the levelers. We are done leveling in less than 20 seconds.
Once she gets it level, I place the chocks and have her put the truck in neutral so it settles on the chocks.
Couldn't be easier
Linc
missing_link is offline   Reply With Quote
Old 05-03-2016, 08:33 PM   #6
Thanks everyone for the comments. I guess I better look at getting two!
Old 05-15-2016, 08:19 PM   #7
Wa11y757's Avatar
Couldn't be easier
Linc
Same here....actually we only used them once. Because, the following weekend an annual site opened up at a local resort. So we booked it for a year. But....they were way easy to use.
Now I'm going back to looking for my 10mm wrench! 2016 Wildwood 27RKSS
2005 F250 PSD
Wa11y757 is offline   Reply With Quote
Old 05-15-2016, 08:26 PM   #8
PokerDealer's Avatar
Thats why I use a 2 X 10. Two sets of leveler's is too much $4.00 for a board
2015 Wildwood 181 BHXL. 2005 1500 Ram Hemi 4x4 W/package
PokerDealer is offline   Reply With Quote
Old 05-16-2016, 06:10 AM   #9
cpaulsen's Avatar
I use 2 of them....one for each axle. So much easier then a bunch of work or the plastic locks. Back in....slide those levelers in front of the tires...pull forward....set the chock.....done!
cpaulsen is offline   Reply With Quote
Old 05-16-2016, 07:18 AM   #10
SeaDog's Avatar
I bought two of the anderson's and they won't work with my flagstaff the wheels are too close together. and like a dum... I cut both so now I have $85.00 worth of junk and use planks that cost me nothing go figure. almost forgot I would level both not just one.
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-17-2016, 09:22 PM   #11
I Have a 2016 rockwood 8311WS travel trailer and I bought two Anderson levelers and couldn't be happier. I did have to trim off about 2 inches from one leveler so it would fit in between the axles. I suppose one leveler would work but it just seems to look better with two. I use a 2 foot level on the side of the trailer to get it level.
Red dog is offline   Reply With Quote
Old 05-20-2016, 06:03 PM   #12
I bought one Anderson Leveler and one Anderson Rapid Jack. I can use the Jack as the second leveler. Don't level very often. I'll have the Jack when I need to change a tire; I use the Jack (on its side) as the trailer tongue jack stand when not needed to level.
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 05-20-2016, 07:03 PM   #13
We use two with our spread axle. Click image for larger version
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 05-20-2016, 07:43 PM   #14
I bought two for our Micro Lite, also needed to cut to fit, so I also cut both to match. IMO if both AL's aren't the same, that's the same as putting different heights of pads under your wheels and saying your axles are level. If you're not at the same position on each AL then your axles are not the same height. That's just how I see leveling.
If you cut yours to fit, then why can't you use them?
fella10 is offline   Reply With Quote
Old 05-20-2016, 08:37 PM   #15
Works well:
leveling
