06-11-2019, 01:56 PM
#21
Originally Posted by ependydad
Personally, I would bring all slides in before re-leveling. I'm not a fan of moving the camper around with them out.
If I had boocoo slides and auto level I would bring them in also.
2017 Puma 297RLSS
06-12-2019, 12:04 PM
#22
Traveling along
I will try the Lynx blocks. I have them and also 2 other sets from Camco. It was the ones from Camco that broke when leveling the TT. Got the Lynx set after those. Have not used them yet.
Bill and Margo
Traveling Along
2019 Silverado 2500
2019 Primetime Crusader 29rsle
06-12-2019, 04:00 PM
#23
Just check the level with a regular carpenters level to see if it's off enough to even worry about it. I use the level on the floor just inside the entry door. Check side to side & front to rear.
2014 Prime Time Sanibel 3250
06-12-2019, 04:21 PM
#24
Exactly. If I don't 'feel' it's off level by walking around, I don't worry about it.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
06-13-2019, 05:48 AM
#25
Thanks to the OP for bringing this topic up. After reading all the responses, I did some more digging and will be changing my routine. We have never felt we were out of level either after putting slides out or after hard rains, it was more of the seeing the pads had sunk into the ground a bit. So probably more of a stabilization concern for us. From now on if I notice this I will just lower the affected jack a bit instead of doing an auto level. Again, thanks for the heads up. Just goes to show we are always learning.
06-13-2019, 02:31 PM
#26
Traveling along
You are welcome. Glad someone else got educated. I get more information from this forum than just about anywhere else. Thanks to everyone!!
Bill and Margo
Traveling Along
2019 Silverado 2500
06-17-2019, 06:34 PM
#27
I am firmly in the camp of “unhook and level before slides out”, but I am curious...
When we stop on the roadside to have lunch, I have to run the two slides out to get access to the kitchen and table. As this is sort of a quick stop process, I don’t mess with trying to level. Does anyone avoid doing this?
2018 FR Wildcat 383MB
2000 F250 CC SB 7.3 ZF 4WD
06-17-2019, 07:01 PM
#28
SO I have wondered about levelers in an emergency...let's say you had a flat tire and needed to jack up one side only in order to change the tire. Can that be done with the leveling system?
06-17-2019, 08:29 PM
#29
Traveling along
Interesting. I will have to open one slide to get the fridge opened. I wouldn't worry about leveling as long as it doesn't feel unlevel. More of a problem would be sure that side of the trailer is protected from someone hitting it. Being curbside, it would be harder to find somewhere safe to open it in normal rest areas.
Bill and Margo
Traveling Along
2019 Silverado 2500
06-17-2019, 08:35 PM
#30
Traveling along
This FW doesn't have levelers that I can individually move to raise one side only. Dont know of any that would. Most TT have manual stabilizers not levelers. They could be used in a pinch.
Bill and Margo
Traveling Along
2019 Silverado 2500
06-18-2019, 02:22 AM
#31
If you are talking a six point hydraulic level-up system, yes you can. I have used the manual function many times to lift one sides tires of the ground. I just put a few blocks under the jacks for that side, so the cylinders don't extend our of range.
06-18-2019, 05:34 AM
#32
We complete the outside set-up and level before we open the door we us camco 12x12 pads ... then adjust steps ... now inside finish up slides turn on a/c etc.... Cindy does inside while I finish unloading ... does anyone use these https://www.amazon.com/dp/B0754MYT4R...ing=UTF8&psc=1 ... I would use on front jacks only I would not have to pull pins and lower the legs?? yes I know they are expensive... I am old and when I crawl/bend well just saying
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
