Originally Posted by NMWildcat
This is one of those subjects where there are several correct answers. Run the placard psi for oem tires, (Under all normal conditions that's the correct inflation pressure) the load chart psi (What is your perception of "load chart psi?), the tire max cold psi, (That's in the optional area.) or somewhere in-between.
All correct.
You just have to decide which one works best for you and your circumstances.
For towable RVs, it's always worked well for me to run the tire max cold psi, even when going up a load range from oem. Especially on heavier trailers. Unlike TVs, RV trailers are always loaded...??...
You may not of had the option to select that as it may have been the vehicle manufacturer's cold recommendation. With tires having load capacity reserves above the vehicle manufacturer's cold recommendations that's always an acceptable option.
In the regulations and standards description for
correct tire inflation pressure, they are referring to the vehicle manufacturer's recommended cold inflation pressures depicted on the vehicle certification label, tire and load information label and in the vehicle owner's manual for Original Equipment tires. Therefore, there can be only one correct cold inflation pressure. Anything else that is acceptable is an option. There are only two options, acceptable and unacceptable. An acceptable option would not violate a safety standard, unacceptable would.
