Old 06-24-2015, 09:54 AM   #41
I have traveled about 65 miles and the cotter pin is still in place. Lubing and re-torquing seems to have done the job. I am surprised they don't put a key way in the shaft and use a tabbed washer like on a axle spindle preventing a turning force on the nut.
2014 Ram 2500 Bighorn CC SB CTD 4X4
2016 Flagstaff 8528IKWS Platinum
2013 Keystone Hideout 23RBWE -Sold
randygk is offline   Reply With Quote
Old 06-24-2015, 09:58 AM   #42
Shouldn't be any turning force on the nut in the 1st place and a 1/4" cotter is much stronger than the tabbed washers used on some spindles.
Old 06-26-2015, 09:37 AM   #43
There must be at least a small turning force as the nut has backed up against the cotter pin. The opening in the castle nut was centered on the hole in spindle when I installed the cotter pin. I will keep an eye on it and I imagine if I do the maintenance procedure every year it should be ok.
Old 06-26-2015, 09:51 AM   #44
It has been my experience that if the cotter pin is installed correctly (seated) the nut can't turn as the castellation is filled with the key. I seat the head and spread the legs out to the sides of the nut.
Old 06-26-2015, 12:50 PM   #45
I'm curious to where you find the "correct" way to install a cotter pin. Not to pick nits, but as a former A&P a lot of the aircraft repair manuals prefer the cotter pin install with one leg bent over the end of the shaft (bolt flat) with the other way optional. But I see your point where going perpendicular would indeed fill the openings and prevent any movement. Alas we may be beating the proverbial dead horse.
Old 06-26-2015, 12:56 PM   #46
PS- Thank you for your input
