Old 05-02-2014, 04:40 PM   #11
Bearing Buddy's DO NOT BELONG on trailers with brakes. They will push grease past the seals onto the brakes. Ez Lube axles do not do this, the excess grease comes out the front.
Old 05-22-2014, 11:06 AM   #12
How do I know which axles I have?
I bought my 2006 Shamrock 23SS used and it came with no paperwork. Which do I have or how can I tell? I want to do maintenance before heading out later in June.
1960es is offline   Reply With Quote
Old 05-22-2014, 06:18 PM   #13
H2oski
Is there a metal data plate or sticker with manufacture and part number on your axle?
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 05-22-2014, 06:37 PM   #14
Pull the hubcaps and look. If you see a rubber cap, pull it and you will see a zerk. If you see a full metal cap, you will have to pull it, and take the hub off to grease.
Old 05-22-2014, 06:40 PM   #15
Witch Doctor's Avatar
I would think that you had al-ko axles. Do you have a black rubber plug over them? If so they are. You will have zerk fitting behind that if you do, Pump some 400 degree grease from napa in them until it comes out, then just wipe the excess off and you are done. Buy Red Lukas. it meets the specs.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 05-22-2014, 09:54 PM   #16
gljurczyk and OldCoot,
Thanks for the assist. I am new at this so I really appreciate the help. Concerning the other reply....informative and obnoxious all at the same time. Impressive!
Okay, that came out a little over the top but I couldn't resist.
Just having fun.
Old 06-23-2014, 06:59 PM   #17
Sg6923's Avatar
I just got a quote from my local RV retailer for repacking my bearings. The cost would be $240 plus tax or $60/wheel. Seems that's reasonable. I'll likely have the brake pads/calipers checked out while they're in there.
Sg6923 is offline   Reply With Quote
Old 06-23-2014, 07:15 PM   #18
VinceU's Avatar
That's a very important task, and if not performed well can ruin your day. Why not get a quote from a local shop that specializes in brakes and bearings? There's a couple of chains. Would give me piece of mind, I'm sure you also.
Old 06-23-2014, 07:18 PM   #19
Sg6923's Avatar
Good idea! Places like Goodyear and Gateway I've found don't like to deal with anything they can't put on a rack. I will check a couple out.
T-Man
Old 06-24-2014, 05:47 AM   #20
That really is not a bad price to do. I don't think you will get it cheaper anywhere. That's only $60.00 bucks an hour my dealer will charge $90.00 per hour. Should take about an hour a wheel or so to do it right. And you are correct have them check everything while they are off and also have them adjust them if they are not the self adjusting type......I would go for it.......
bearings, wheel
