Old 12-11-2011, 07:17 PM   #1
Mountainmanbob's Avatar
(repair) loose screws falling out
yes
the old common problem
especially on travel trailers and motor homes
just checked mine over
loose screws about ready to fall out on door shock
solution
couple of tubes of JB Weld (5 min type) epoxy
put just a little around threads
and screw in snug
that screw should stay in there now
had my awning bracket pulling out
on the old motor home we had
don't want to lose that THING while on the road
packed the sloppy hole with JB
then some more on the threads
never had another problem with it
if only a slight amount of epoxy is used
the screw can still be taken out if wanted later
someone on site does not like my format
((as was stated in another thread))
what you see is what you get
from
up top the mountain
Mountainmanbob
Mountainmanbob is offline   Reply With Quote
Old 12-11-2011, 08:51 PM   #2
Taranwanderer's Avatar
JB Weld is a rather permanent solution! I might try Loctite first before I go for the big guns of JB...if you ever want to get that screw out for any reason!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 12-12-2011, 05:38 AM   #3
from
That is what the ignore feature is for
mike047 is offline   Reply With Quote
Old 12-12-2011, 06:53 AM   #4
got them many more miles
hi Taranwanderer
they back out later no problem
just don't use too much
Loctite is better for tight good fitting nuts and bolts
JB Weld would be for sloppy holes
for super sloppy spaces
one can
put some JB Weld into the hole
some more on the possibly stripped threads
of the nut or bolt
then drag some very fine string or thread
through some epoxy
and wrap it around the screw
then screw it in
while doing repairs in our bicycle shop years ago
many many times we made similar repairs
crank housings totally stripped out
we found that epoxy held (with string)
and still broke loose later
note
I will admit
a repair such as that on a stripped bicycle crank
is not a good THING
but
the only alternative was
to throw the frame away
Mountainman
Old 12-12-2011, 07:44 AM   #5
Originally Posted by Mountainmanbob View Post
if we look towards the top here frankman
we will see where I started this thread
you have added nothing here
why don't you
play in your own back yard ???
Mountainman
Frank is right. I don't bother to read most of what you write because
of the format you use. It's really annoying, so why do it?
Len & Cheri is offline   Reply With Quote
Old 12-12-2011, 08:35 AM   #6
send private messages
I gess we could say
that it has become my trade mark
as used also on serveral other internet sites
with no complaints (after soom time that is)
usually
one's who have problems
so as not to distrube said thread
this would be the courteous THING to do
Mountainman
prox
12 years water well testing GPM
15 years Equip Tec City of San Diego
specializing in water delivery systems
and
repairs of small engines, tractors etc
15 years Equipment Operator City of SD
bicycle shop owner
note
not necessarily here to make friends
just to possibly
help a few out with their (simple problems)
do not consider myself an expert
regarding RV's or trailers
Old 12-12-2011, 08:44 AM   #7
MtnGuy's Avatar
mountainmanbob's format has been addressed several times now. A couple of threads I had to delete to prevent a flame war from starting. Let's get back to the subject of the thread.
mountainmanbob's format will be discussed by the moderators to see if it is appropriate on the forum.
Anyone can use the ignore button so that they do not have to view mountainbob's posts.
Old 12-12-2011, 09:05 AM   #8
Rugged Brown's Avatar
Yo Mountain Bob is a freestylin rapster
He sings to the beat of a RV Camper
He says what he says
whether you like it or don't
Just click the "ignore"
and you won't see his font
He does his best
to offer his view
some hear his words
But I think its a few
The moderators here
will judge how he presents
If it annoys quite a few
I guess he'll be absent
So, Yo Mountain Bob
you can do your stuff
but the time may come
when it won't be up to snuff
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 12-12-2011, 09:14 AM   #9
He does his best
to offer his view
some hear his words
The moderators here
So, Yo Mountain Bob
Nice!
Old 12-12-2011, 02:38 PM   #10
KyDan's Avatar
I gess we could say
usually
My take on your center justified text is that it's annoying and difficult to
read. You say it is your trademark but it draws attention to you personally
and away from the original subject of the thread.
Note how this thread has veered completely away from the original
subject.
You further say you aren't here to make friends. We try to keep this
site as friendly as possible.
We'd be much obliged if you'd type your posts in that spirit.
Peace!
Dan & Rita D
Blue Ox WD hitch
