Old 04-19-2016, 09:36 PM   #1
Repairing bent hydraulic landing gear leg
I have to replace/repair a bent hydraulic landing gear leg on my
Cardinal 5th wheel. I'm worried that when I disconnect the hydraulic lines I will spill a lot of fluid. Would it reduce fluid loss if I pulled shore power and removed battery connections in an effort to minimize pressure in the lines. Any other suggestions would be welcomed.
Ed
edshirl is offline   Reply With Quote
Old 04-20-2016, 05:49 AM   #2
I'm not familiar with your unit but I do work on hydraulics in my field. If you disconnect the battery it will keep the system from try to self level (if it's full auto). In general, the pressure will not/should not change until you break a line loose. If the control valves are in good condition you should only loose what is in the lines. You need to get all of the weight off the unit and support the trailer frame on both sides just in case the other leg leaks down.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 04-20-2016, 09:56 AM   #3
Mars, thanks for your reply. The Cardinal is not self leveling, with only the front landing gear controlled by an extend/retract switch. The unit is already supported on blocks, so now I'm just waiting for the courage to disconnect the lines.
Ed
Old 04-20-2016, 10:01 AM   #4
AquaMan's Avatar
Ed
Also remember that one drop of hydraulic fluid on your clothes and you will soon be covered from head to toe. That might be slightly exaggerated, but it does make a mess if spilled.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-20-2016, 10:57 AM   #5
Sure does, kitty litter helps.
Just crack open the hose fittings slowly with a rag over it. If possible tie the hose ends above (higher) the reserve tank to minimize the siphoning effect.
Old 04-20-2016, 11:06 AM   #6
2007 WildCat 32QBBS
05CrewDually's Avatar
If you want to ensure there is no pressure, disconnect just the hydraulic pump motor's wire. Once that's disconnected cycle the switch up and down. You should hear just the valves clicking. This should allow the pressure to equalize. You'll still get some drips, just have some rags ready and tie the lines up so the fluid doesn't run out.
05CrewDually is offline   Reply With Quote
Old 04-20-2016, 11:23 AM   #7
AquaMan's Avatar
Knowing where the tank probably is and where the lines are, I doubt that you will be able to tie the lines above the tank level. Pull the lines and let 'em drain.
Old 04-20-2016, 11:48 AM   #8
Thanks for all your comments and suggestions. (although my confidence hasn't improved any)
Ed
Old 04-20-2016, 12:05 PM   #9
AquaMan's Avatar
You'll be fine Ed! Tear into it! It's not like you're cutting a hole in the side of it! (That took some courage). 😀
Old 04-20-2016, 07:51 PM   #10
vasnipe's Avatar
I suggest using a motor oil catch pan or some such to collect the fluid that does come out. That way you don't make too much of a mess. Do have the kitty litter on hand in case Mr. Murphy shows up. Oh, and Mr Murphy will ensure that the hydraulic oil will jump all over you, so old clothes or coveralls would be in order.
Good luck and be careful out there.
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
bent, hydraulic, repair
