Old 08-20-2018, 05:07 PM   #1
replacing flooring with laminate
ok well i tore my floor twice already, they are warranting the first one but id like to swap it out to a laminate if poss, has anyone done this?
thanks
2018 Puma Unleashed 373 QSI Toy hauler Fifth wheel
Firedude26 is offline   Reply With Quote
Old 08-21-2018, 06:01 AM   #2
Professional Curmudgeon
wrvond's Avatar
Installing laminate flooring is a very common mod in the Class 'A' world. I have a 5er that the PO replaced the vinyl portion of the floor with laminate. He did a good enough job that unless you look really close, it appears to be factory installed.
Your biggest issue, as I see it, is going to be getting clearance between the thicker laminate floor covering and any slides you might have. Really not sure how you can address that. In my camper, the area in front of the single slide was left carpeted.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
floor, flooring
