Old 07-06-2015, 03:22 PM   #1
Rotating tires
Who rotates fifth wheel tires? I have a 35' 5er and want to know if people rotate tires and at how many miles
sbreen is offline   Reply With Quote
Old 07-06-2015, 03:42 PM   #2
Sc00ter's Avatar
I do it once per season when I inspect/repack the bearings.
Sc00ter is offline   Reply With Quote
Old 07-06-2015, 04:01 PM   #3
Never have and never will. The reason for rotating on a car/truck is 2 are steering/providing traction and 2 are trailing/providing traction. On a trailer, all 4 are just trailing, neither steering or providing traction.
Old 07-06-2015, 04:36 PM   #4
I was thinking for a wear issue. To make sure you get even wear for all 4
Old 07-06-2015, 04:44 PM   #5
Pauls Toy Hauler's Avatar
I am ( and I think most ) are replacing tires due to age rather than being worn down. I have not rotated any of my tires and the last time I replaced all 4 with brand new ones I think the tread was probably at 60%. they just got old and two showed real bad signs of dry rot due to sun and moisture.
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
Pauls Toy Hauler is offline   Reply With Quote
Old 07-06-2015, 04:50 PM   #6
I think that is what OC was referring to. The trailer tires are just rolling behind you 99% of the time so the wear should be even side to side. Unlike a car were to two front tires need to steer the car and drive it forward (fwd car). So the wear is different front to back. If you have an alinement issue then you will have different wear side to side.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
tire, tires
