06-29-2016, 08:22 PM
RV Height
So , this August I'm finally getting my new man shed built. 46x72 with 16' sidewalls. My question is this, installing a 12'x14' high overhead door. Will this door be adequate if we decide to upgrade to a 5er? Is it more than adequate that I could go to a shorter door which I could then widen? Possibly shorten the bldg? What is the average height of new 5ers?
06-29-2016, 08:31 PM
My guess is that most are going to be 13 - 13.5 feet tall. Can't really go higher because you'd run into clearance issues.
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 29
06-30-2016, 04:27 AM
RV Height
I have a 12W x 14H door with a 5th wheel. You want 14H to cover any type of RV. Some 5th wheel height specs don't include the optional front AC. My measured height is 13'4".
A 14 x 14 door would be awesome !
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
06-30-2016, 04:43 AM
The tallest you can be going down the road with out special over size permits is 13"-6", I have to assume 14' would be fine.
Me personally, I would want a wider door... Most campers are 102" wide and that doesn't include the awning roll, which would put you at roughtly 9' wide. Backing a 9' wide camper into a 12' wide door gives you just 18" on each side... Certainly duable, but will be tough to put the camper anywhere but straight in in the center of the shed.
I am building a new building next summer, but my current shed has two sliding doors and a 20' opening... its a breeze to back thru even on an angle to put the camper along one side.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
06-30-2016, 05:33 AM
Frog-Toberfest Organizer
My 2016 Vengeance is 12' 8" tall With front A/C so I would stick with the 14' tall door but go wider if possible.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
06-30-2016, 06:55 AM
Leave your walls 16' and make your door 14'. This way you have plenty of clearance without having to use a low clearance track like I do. My door is 13'9" and my walls are 14'. It's too tight for me. We made it work but I would rather have had 16' walls.
2015 Chevrolet Silverado 2500HD 4x4 Z71 Duramax/Allison Combo Pull Rite, ISR Series Superglide 16K, LoadLifter 5000 Ultimate W/ WirelessOne
Current RV: 2016 Palomino Columbus 381FL Fifth Wheel
Lippert Flex Air Pin Box, LT235-85-16 GY G614
Nights Camped 2013 - 6 • 2014 - 7 • 2015 - 12 • 2016 - 29 • 2017 - 16 (17 more planned!!)
06-30-2016, 06:56 AM
My Palomino is 13'5" on the truck with 2nd AC option btw.
06-30-2016, 07:01 AM
Camp Bartender
Heres a side note, sorry to hi jack the post question. My 28DBUD says the height is 11-2", generally, does that mean to the top of the highest point of the equipment on the roof which would be my AC, OR from the ground to the edge of the roof?
2017 Dodge Ram 1500 Big Horn, 5.7L HEMI
2015 Forest River Wildwood 28DBUD
2015-2018: 20 Trips, 61 Nights Camped
2018: 5 Trips, 15 Nights Camped
2019: 2 Trips, 10 nights so far......
06-30-2016, 07:19 AM
I would caution you about getting the height correct. For example if you go to Palomino's website right now and look at the 381FL it says the height is 12'6" without 2nd AC option. However looking closers you see that this is the 2015 models brochure. The 2016's with the 2nd AC are like I said above 13'5".
Typically on TT it will be the top of the AC unit.
06-30-2016, 07:27 AM
Also make sure the door on the barn for does up that high. The door opening is usually 14 but the door typically hangs down a bit when open.
06-30-2016, 07:31 AM
Another thing if you do consider the wider door, is that it will admit a lot more natural light. I have a canopy with open ends, and the sides stop at 3' off the ground. I like lots of light.
2011 Sabre Silhouette 260BHS
2017 F-350 XLT CC DRW 6.7L
06-30-2016, 07:43 AM
AGFazio makes a good point, it was going to be my contribution to this thread but I wasn't quick enough. Unless you have a door the slides open (to the left or right) you aren't going to get all 14' out of the opening. I don't have a garage for my RV (yet), but my "regular" garage at home is a 7' opening, but I can only get a vehicle inside if the vehicle is less then 6'7" because of the way the tracks/door is positioned when open. If that makes sense?
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
06-30-2016, 07:53 AM
Not always. My door is 14' and my opening is 13'9. My door opens just above the opening.
07-01-2016, 09:45 AM
Mine door 14' tall and doesn't pose any issues for our Sandpiper. It is also 20' wide so we can easily position it anywhere within the garage when needed. The wall height is 16'.
2016 Sandpiper 376BHOK
2500HD Chevrolet
07-01-2016, 01:16 PM
Attachment 112752
Attachment 112753
2500HD Chevrolet
Who was your building manufacturer?
2012 F350 CC SRW 6.7
2012 Sabre 34-REQS-6
2012 F-350 SRW 6.7
2012 Sabre 34-REQS
07-01-2016, 01:51 PM
-2015 Wildcat 317RL
07-01-2016, 01:53 PM
Looks to have a Morton Buildings sign on the front.
07-01-2016, 01:57 PM
Hmmmm. I don't see a bunch of crap in either shop?? What gives?
2017 Puma 297RLSS
07-01-2016, 03:52 PM
It was built by Morton.
2500HD Chevrolet
Originally Posted by Learjet
Sweet!
2500HD Chevrolet
