Old 06-04-2015, 09:55 PM   #1
RV Storage electric
when storing my travel trailer at the storage facility should I leave the trailer connected to shore power?
twentz is offline   Reply With Quote
Old 06-04-2015, 10:05 PM   #2
TURBS's Avatar
If you can i would.
Just keep an eye on battery water levels.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-05-2015, 03:54 PM   #3
While I keep my fiver at home, a small ranch in SE Texas, I keep the power on and ACs set on 80 F. It gets very hot and humid here.
whj77372 is offline   Reply With Quote
Old 06-06-2015, 09:19 PM   #4
Thekipkers's Avatar
I was told by someone that TT do not have trickle chargers and to not leave them plugged in, others have said no problem.
We rotate every other week unless we know we are going out then I'll leave it plugged in and the fridge running
SK2 Camping Crew
2010 Ford F-350 Lariat
2015 Heritage Glen 356QB
Thekipkers is offline   Reply With Quote
Old 06-06-2015, 09:44 PM   #5
Flybob's Avatar
I do not plug TT in until a day or so before heading out, but I do have a battery tender (TM) hooked to the battery ( still installed in TT) that is plugged in whenever the TT is not connected to shore power.
http://www.amazon.com/Battery-Tender...N%3DB000NCOKQK
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-06-2015, 09:49 PM   #6
camaraderie's Avatar
If you leeave the battery fully charged with the negative post disconnected there is ZERO need to plug in more than once every couple of months for a day to re-charge. Fully charged batteries disconnected will lose 10-15% a month making even 3 months of non use, not a problem. Your batteries will also last longer if they get an occasional bulk charge rather than a constant trickle.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
electric, storage
