Old 12-17-2009, 11:24 PM   #1
Safety brake line from king pin to truck??
I just purchased my first RV, a 5th wheel Cardinal. When I picked it up the dealer was helpful, but when it came to a few things they just kind of looked at me with a blank expression. For example, they showed and explained to me the safety brake line and how important it is for stopping the trailer if it should separate from the truck. They said take care where I hook it on the truck and be sure it does not snag. I have a Reese 16K hitch and looped the line over the Reese release handle. Seemed close enough for turns and I did not see any obstructions. That is until I made my first sharp right turn and the safety clip came out of the holster. I figured this was a fluke until it happened again. Now, I need some help. Where in the H --- do I attach the line? I have a new F250 with the step option on the tail gate and I am thinking of looping it on the post for climbing up the step. Can anyone give me a better place or method of attaching the line?
I do not want the trailer locking up on me again.
Big Bird
Big bird is offline   Reply With Quote
Old 12-18-2009, 02:36 AM   #2
Not familiar with the Reese- I have a pullrite slider. I pull the pin in the rail on the drivers side, feed the loop in and put the pin back in thru the loop. Figure if the hitch goes anywhere. the bed rails will stay. I think you can also get longer cables at camp supply stores.
MightyMike is offline   Reply With Quote
Old 12-18-2009, 04:46 AM   #3
cardinal4fun's Avatar
I added a snap ring to mine, snap it through one of the holes in the hitch. It can be attached most anywhere as long as it stays out of the way.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 12-18-2009, 06:42 AM   #4
bsmall's Avatar
That is exactly what I did with mine also....
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 12-18-2009, 08:52 AM   #5
Head Rambler
I like MightyMike's idea of not pinning it to the hitch. In the one-in-a-million chance that the hitch comes loose you want the break-away to engage.
Gotta go campin!
Old 12-18-2009, 11:24 AM   #6
Thanks,
I am a little surprised the trailer manufacturer, or the hitch manufacturer do not consider the cable and provide at least advice on how to connect. Goes to show that people who use them usually know more than the people who make them and the makers do not listen to the users.
Thanks again,
Big Bird
Old 01-24-2010, 10:24 AM   #7
Woody 01's Avatar
I use a pad lock and lock the cable and the hitch release at the same time
That way I do not have some A#$ H@#* pull the release while I'm in a parking lot or something.
Steve & Nicole Wood
Luke 10 & Morgan 7
2003 Rockwood 8281SS 5er
2002 F-250 Super-duty
Woody 01 is offline   Reply With Quote
Old 01-24-2010, 07:19 PM   #8
+1
same thing here
Fencer is offline   Reply With Quote
Old 01-25-2010, 08:31 AM   #9
MtnGuy's Avatar
So, I am not the only one that is supscious of someone throwing the latch on my trailer hitch while parked. I keep a padlock on mine, also.
Old 01-25-2010, 09:40 AM   #10
As an old semi driver told me once, if you leave your truck for any length of time, before you pull forward, hold trailer brakes and back up. This will re-latch your 5th wheel, in case somebody has been playing games. Good habit to get in to.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
5th wheel, brakes
