Old 10-10-2014, 11:40 AM   #1
salem slide
I have a 2013 Salem 23 ft the slide won't move. There is power but nothing to the slide motor. Is there another fuse or breaker I don't see? Model T23FB
starcraft16 is offline   Reply With Quote
Old 10-10-2014, 11:43 AM   #2
fonzie's Avatar
Post what model you have, it helps searching for the proper response.
Fonzie
Old 10-10-2014, 03:30 PM   #3
Looks like he posted the model number at the end of his post.
Starcraft, did you inspect the fuses in the converter? Next step would be to open the switch on the wall and verify power is reaching the switch, then jump the wires on the back (in or out, depending on which way your slide is stuck) to verify if the problem is in the switch itself. Next, pierce the +12 wire at the motor and verify power is getting to the motor (while someone presses the switch, or jump-wire the back of the switch again). If you are then the motor is probably bad. If you aren't, next move your battery under the chassis and jump directly to the motor's wires to verify the motor is good.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 10-10-2014, 03:33 PM   #4
fonzie's Avatar
[QUOTE=techntrek;717191]Looks like he posted the model number at the end of his post.
Yes he edited his post after my request.
Fonzie
Old 10-13-2014, 05:23 PM   #5
salem slide
I was checking switch and wires found no power checked batteries all okay. Checked fuses and found the one marked fans, sensors blown. replaced fuse and all is well. Thought just the slide fuse was all needed checking but will be sure to check all from now on. Thanks for all the help
salem, slide
