Old 04-14-2019, 09:30 PM   #1
salem/wildwood 4092BFL
I put this in the general forum as it affects both models. In the loft the two windows are the handle type where you must straighten the handle before you push it out to open the window. The problem is they put the windows so low the mattresses interfere with opening the window. Has anyone else figured out a way around this? I suppose it may be possible to replace the windows with slider windows but that does not sound very economical if they even make one the same size.
gvysk is offline   Reply With Quote
salem, wildwood
