Old 04-20-2013, 07:29 AM   #1
mjones12's Avatar
scissor jack lube
I have new scissor jacks and upon first deployment I could feel a little bit of hesitation or "catch" in a couple of them. I have a spray can of grease that comes out in a white spray. Would that be the recommended treatment? Thanks.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 04-20-2013, 07:33 AM   #2
Lynkage's Avatar
That will work fine. A more permanent solution would be to use some bearing grease on all the screws
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 04-20-2013, 07:36 AM   #3
Fulltime family RVer
I don't use anything that stays wet when it comes to things that are exposed to dirt and debris. I use a dry silicone or graphite that ends up as a film/dry.
ependydad is online now   Reply With Quote
Old 04-20-2013, 07:36 AM   #4
mjones12's Avatar
Thank you for a prompt and helpful response.
Old 04-20-2013, 07:37 AM   #5
Even if I do have to reapply regularly.
Old 04-20-2013, 07:38 AM   #6
mjones12's Avatar
I see your point. Eventually grease would gunk-up the works, I guess.
Old 04-20-2013, 07:40 AM   #7
That's my take- but many people do use grease and don't want to switch. Different strokes and all that jazz.
Old 04-20-2013, 07:51 AM   #8
Lynkage's Avatar
I own heavy equipment and have always used grease. If you want very good grease then use high pressure lithium. Dry lube works well on some things too. If you like the spray application then that is ok too. One thing is for sure you will someday need to clean it all of and start again.
Shane & Antoinette
Old 04-20-2013, 07:59 AM   #9
And a pressure washer makes short work of cleaning them. Not a major problem regardless of the lube you use. Use whatever you feel comfortable with. Farmers and folks like Linkage have been using grease for years and years with no problems on dozers, tractors, etc.
Old 04-20-2013, 08:25 AM   #10
mjones12's Avatar
All very good points. Thanks to all of you. Yes, I couldn't think of the name until Lynkage mentioned it, but lithium grease is what I have in the spray can. Easy application. I guess anything is better than running them dry.
