Old 06-23-2010, 09:22 AM   #11
Procedure for leveling trailer that works for me.
1. Park trailer where it will be unhooked. Check awning and door clearance, and slides if you have them.
2. Read side/side level on trailer and determine low side and how many boards I need. I carry 2x6's and figure 1 inch per board.
3. Put boards down beside trailer tires.
3. Pull trailer up, move boards over, back on to boards.
4. Check side/side level, hopefully within 1 inch. If not, add/subtract boards. When side/side level is good, chock wheels with ground chocks, unhook trailer. Do not install "X" chocks yet!
5. Level trailer front/rear with tongue jack.
6. Check side/side level, and start making adjustments with corner scissor jacks, low side first. Raise this side till level, then add one or so turns. Now lower the high side jacks, adding a couple of turns after ground contact.
7. Now install "X" chocks if you have them. Putting them in before the front/rear is level may cause them to get loose or very tight as the suspension moves when leveling front/rear. These should be the last things added, and the first removed. You also should install ground chocks front and rear of tires on at least one wheel or one side of the trailer before unhooking, and leave until you are hooked back up. Also when unhooking, I leave my safety chains connected until my coupler is clear of the ball. This is in case the trailer start to roll off on it's on, the chains should catch it before it gets too far or does any damage.
This procedure may or may not work for you, but it works for me. Feel free to use any or all that you like. I think it took longer to type it than it does to do it.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-23-2010, 09:37 AM   #12
So would everyone suggest buying a pair of stabilizers to go along with my "1 arm" stabilizer jacks?
masonga is offline   Reply With Quote
Old 06-23-2010, 11:01 AM   #13
MtnGuy's Avatar
Originally Posted by bmg View Post
I hope there's no prohibition against asking dumb questions, because I'm probably about to. I've tried to research some of this, but both the owners manual and my Woodall's RV Handbook don't even talk about the stabilizers/jacks.
I'm under the impression that the stabilizers are not referred to as jacks since you can't raise any weight w/o breaking them. In talking to Camping World it seemed that they wanted to remove the stabilizers and replace them with the scissor jacks. From what I'm sensing here is some of you have both and have the scissors installed closer to the axles. Am I understanding that correctly? If so it would seem that the sequence would be: 1. leveling with boards under the wheels, 2. chocking the wheels, 3. using the scissor jacks for minor leveling, and 4. putting down the stabilizers to secure the corners. Am I on the right page here? Any feedback would be greatly appreciated.
There are no dumb questions......everybody had to start exactly where you are at some point in their camping history.
I think most people that have the scissors jacks are in the far corners where the original stab jacks were......I don't think people have both.
In have the 1 arm stabilizer jacks, and yes they are flimsy. If the time arises after those puppies break a couple of times, then I might add scissors jacks, being sure not to tighten them too much. So far, the 1 arm jacks that I have seem to work great, and I am in no hurry to replace them if they continue to work.
I another post on this thread, someone asked whether 2 rear jacks are enough. They are a plenty if you don't mind the trailer rocking a little.......and it will always rock some unless you put it up on blocks. . Those rear jacks, along with the tongue jack give you decent stability acting as a tripod. If you just have the rear jacks, I would suggest using that setup for a couple of camping trips before going to the cost and time of adding 2 more up front.
Old 06-23-2010, 05:35 PM   #14
bmg
One tip I picked up from the park manager on our first shake out weekend, was to make sure the refrigerator was perfectly level. He recommended using the 360 degree level that came in our starter kit. So to fine tune everything we adjusted to that level and everything was fine. He said that a big mistake new owners have is not leveling the fridge and after 5 or 6 outings they quit working.
We had an unlevel site,but was finally able to get it level with the help of a portable hydraulic jack. I'm hoping that by installing the scissors we can level everything much easier.
bmg is offline   Reply With Quote
Old 06-23-2010, 06:01 PM   #15
Herk7769's Avatar
Windrider, One addition (don't ask how I know) is to check the pedestal with a power tester, the water spigot for water, and where the freakin sewer connection is located BEFORE you level, disconnect, etc.
Oh and since space is a real issue in my shortbed TV, I use 1 foot long pieces of pressure treated 2x6 and 1 foot long pieces of pressure treated 1x6 decking for leveling. That way I can back up onto them 1 foot at a time stacking if I need to. (Back onto the first board. DW says stop. Stack 2 boards. Back again till DW says stop.) By mixing 2x and 1x I can always get it perfect. I store them in an old milk crate.
HAM CALLSIGN - KC3FFW
Old 06-23-2010, 06:15 PM   #16
milzat's Avatar
I received a set of scissor type jacks yesterday. I'm going to replace the stabilizer jacks, on the rear, with the new scissor jacks. Then, I'll install the stabilizer jack, removed from the rear, under the center of the trailer.
I'm also going to make a set of jack supports.
See photo below.
This, along with wheel chocks, will stop the shaking.
milzat is offline   Reply With Quote
Old 07-21-2010, 10:35 PM   #17
bmg
Smile
Thought I'd update everyone on my research to this point. First of all in reading a lot of threads here and other places, there seems to be a difference of opinion between those that own the lite trailers and others with heavier, more substantial frames.
In general, the lite owners are saying not to put the scissor jacks on the rear since too much torque could twist the frame. The heavier trailer people are not concerned about bending anything. The main concern with both types is to use the jacks for minor adjustments, an inch or so, and to make sure the wheels maintain good contact with the ground.
Ours is a lite, an SV264, and loaded should only be about 5000 pounds. I'm planning on leaving the rear stabilizers in place and installing a pair of scissor jack just behind the wheels. That way in leveling, we can get the side to side level within and inch or so with boards and then use the scissors to finish the level. The 4 stabilizers, front and back, should give little or no motion, especially with the roto chucks I've ordered.
I'm leaning toward the BAL 24'' jacks. I can get the pair locally for $60.
24" Scissor Jacks - Product - Camping World
Let me know, if I'm missing anything. This seems to be the best option for our lite trailer.
Old 07-22-2010, 07:32 AM   #18
MtnGuy's Avatar
Just be careful with those scissors jacks on an I-beam frame. If you notice, there is extra support bridging the gap between the I-beams where the axles are mounted....... there is a reason for that.
Old 07-22-2010, 12:17 PM   #19
bmg
Thanks for the tip. I'll be extra careful. I think if they're close to the axles and are used for slight adjustments, I'll be ok. I may have Camping World install them. I don't know about drilling through the beam; although I do have the tools to do it.
Just realized we'll be near your area the first week of August. We're want to stay between Charlottesville and Richmond if possible. We're considering the Small Country Campground in Louisa or the KOA just south of Charlottesville. We need a good wifi and a site where we can put the satellite dish. Anyway, we'll hit a few more Civil War sites (or is it the War of Northern Aggression sites?) while we're in the area.
Old 07-22-2010, 12:27 PM   #20
Herk7769's Avatar
Do you have access to military bases? Quantico has an awesome Famcamp.
