Old 05-07-2016, 04:32 PM   #11
wicked1's Avatar
Originally Posted by CWSWine View Post
If you looking at the Montana line you need to stay away from the plain Montana because it real heavy 5er and some huge pin weights. The Montana High Country Country is one step down from the Montana and one step up from the Cougar but has lighter pin weights.
I would also stay away from dark color caps not matter what the brand unless they are painted, they are having problems with fading and chalking.
I would read the forums about that model and see what problems others are having. The small stuff is not a problem but lot issues bigger issues is a problem.
Yeah Looking at the Montana HC, not regular Montana. It is just the Wife and I so don't need anything too long or heavy/fancy I like the Cougar 333mks just need to see if ppl are having luck with them
2016 F350 SCREW SB 6.7 PS Diesel
2015 FR Rockwood Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 05-07-2016, 04:35 PM   #12
CaptnJohn's Avatar
I have a Cougar and love it. Not the type of shower you want in the 303RLS. The only reason mentioned is we found zero at the PDI (dealer prep maybe) and have only had 1 minor problem that Atwood sent a tech out to a CG to fix. Have pulled it over 2000 miles and used about 40 nights so far. The fireplace did the job until temps dropped below 40 then we used the furnace. The polar pkg is advertised to zero but I never intend to find out. Never gets that cold here and we winter in FL.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 05-07-2016, 04:51 PM   #13
Big Rig's Avatar
Just looked at the Montana's and loved the front kitchen model. I'm just not a big fan of Montana quality. Grand Design is still my first choice when time to replace my current Rockwood fifth wheel.
Big Rig is offline   Reply With Quote
Old 05-07-2016, 04:55 PM   #14
2015 Silverback/2014 F250
Silverbacks from Cedarcreek are really awesome trailers you might want to consider looking at a two or three-year-old silverback the new models have got the fridge that will open with the slides closed you might want to consider that most of them will be a round 30 to 40,000
chisumbella is offline   Reply With Quote
Old 05-07-2016, 06:32 PM   #15
wicked1's Avatar
Good to know bc I am seriously looking at the 333mks, we saw it at a show and love the layout
Old 05-07-2016, 06:37 PM   #16
wicked1's Avatar
Slightly over my budget and they are fairly heavy I am trying to stay under 12,000 and 2200 Pin weight just so I have a good margin or safety
Old 05-07-2016, 10:07 PM   #17
CWSWine's Avatar
I think the front kitchen was unique but putting all the weight forward right over the pin would cause me a truck upgrade again. I have the front living room model and like it but it's 39.5 foot long which does cause problems with side winds. I wish I stayed in the 33 to 36 foot range and not full 13.6 profile, just to big of sail behind for 143.5 " wheelbase SRW F350. I'm had on the CAT scale a couple of times and within specs but that doesn't always tell the entire story.
I had a Cougar 28SGS and really like it and probably should keep that one and never had one single problem with it...
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 05-08-2016, 12:04 AM   #18
wicked1's Avatar
Yeah I am trying to really stay in the following Zone any bigger just creates issues and since it is just the Future Wife and I, do not need a lot of space.
Priority
No longer then 33.6 Feet
No Heavier then 12,000#'s
Pin no more than 2200#'s
When I find one that meets our needs in this range, I will be happy also looking at used 2013-2016
Plan on running Anderson 5th Wheel Hitch when I get one, as I have Factory Ford 5th wheel/Gooseneck setup
Old 05-08-2016, 06:35 AM   #19
In case you didn't know, Crusader is made by Prime Time whic is part of the Forest River family
rovinglion is offline   Reply With Quote
Old 05-08-2016, 11:51 AM   #20
I won't go back to FR, but we haven't had our new Keystone Montana long enough to say it's any better than the Wildcat. We know they all have teething problems. Hopefully, the 13 things we identified and fixed during our PDI will be all that's wrong LOL.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
5er
