Old 07-31-2016, 11:59 AM   #1
Secure items in cabinets?
I've spent the last hour searching for what I know has been asked here before, but just can't find it.
How do you secure your items in the cabinets. Overhead and below counter?
Things like cups, plates, coffee maker. Anything in cabinets that could slide.
Here are a few pics of the left over items from our popup that my wife put in an overhead cabinet. I see this as a disaster going down the road. We did get some of that cabinet stuff you put down to keep things from sliding. It just doesn't "secure" it.
ID:	115902   Click image for larger version
ID:	115903   Click image for larger version
kantonburg is offline   Reply With Quote
Old 07-31-2016, 12:17 PM   #2
NMWildcat's Avatar
We use the shelf grip in all the cabinets. I thinks it's a pain but the DW is in charge of that area so I just mind my own business In the upper cabinents we use those cupboard bars you can get at wallie world or CW to keep glass items stationary and to keep items from falling out on us when we first open the cabinet door. Mostly my DW has learned by trial and error what goes where and with what to best survive the trip.
In your pic the packing job looks OK to me. Will it be in the same position after your trip? No.... But doesn't look like anything can get broken.
We always have to do a little cleanup in some of the cabinets after a trip.
Good luck!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-31-2016, 03:00 PM   #3
Good luck!
We have purposely avoided anything glass at this point. I like the cupboard bars. May have to invest in a few of those.
Old 07-31-2016, 03:17 PM   #4
Witch Doctor's Avatar
Good luck!
I have the same problem like everyone, never heard of those cupboard bars what do they look like? I little piece of the non slip works great between plates and bowls. Dose anyone know how to adjust a drawer it keeps opening and I know I will forget to look and that slide will make a big Crunch....I guess I kinda Some of us idiots need pictures, whats a little high jacking between friends...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-31-2016, 03:20 PM   #5
ilmor's Avatar
I just put things closely together and put paper towels between stuff to stop the rattles.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-31-2016, 03:33 PM   #6
Ford Idaho's Avatar
Using the rubber grip stuff and spring tension curtain rods to hold the taller stuff upright.
Old 07-31-2016, 03:38 PM   #7
NMWildcat's Avatar
They make many different sizes and types but all are adjustable by the use of an internal spring. Here is a link to one:
https://www.etrailer.com/dept-pg-RV_...oard_Bars.aspx.
As far as the drawer, some have adjustable hardware. Mine didn't so I went to home depot and got some 10lb drawer latches and screwed them on. They make them in different pull strengths.... 5lb, 10lb,...... I can't find a pic of that one right now though.
Old 07-31-2016, 03:38 PM   #8
https://www.amazon.com/Camco-44063-C...s=cuppord+bars
Old 07-31-2016, 04:26 PM   #9
NMWildcat's Avatar
Found a pic of some. They make all kinds, metal/plastic top mount, side mount, etc. One similar to what I used (the battalion grab catch):
https://www.grainger.com/category/ca...ecatalog/N-mzf
A side mount: https://www.amazon.com/Southco-SC-43.../dp/B002I05TUQ
Hope you can find one that works for you.
Old 07-31-2016, 04:33 PM   #10
Fulltime family RVer
For (our Corelle) plates, we stand them on end in a small hard container. We stack our (also Corelle) bowls and put them into the same container- that keeps them under control.
Then we keep our cups cabinet under control with "slotted interlocking" drawer organizers. We initially found them at The Container Store and later found them at IKEA.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
ependydad is online now   Reply With Quote
cabinets
