Old 07-06-2011, 10:25 PM   #11
I was reading the leaflet which comes with Lynx levelers recently, and they say that one should only lift one axle to level the trailer .... I thought that was weird as I always lift both axles ..... If I can find it again , I will re-read and confirm ...
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 07-07-2011, 01:18 AM   #12
flyrotor's Avatar
my trailer has springs, the yoke between the springs allow distribution to the axles equally up to a certain point. Like many here have stated I will put blocks under one or both of the tires to achieve the desired amount of lift. I will never put two blocks under one axle without having at least one under the other axle. I also carry a shovel and will often dig holes for the high side wheels to drop them, granted this takes a minimally improved camp site as I don't want to cause problems with any camp managers. Holes make excellent wheel chocks by the way.
flyrotor is offline   Reply With Quote
Old 07-07-2011, 07:02 AM   #13
Herk7769's Avatar
Tri Lynx Levelers
The photos show trailer type (dual axles) with a Lynx under each wheel.
The instructions do not mention using only one wheel on a side.
HAM CALLSIGN - KC3FFW
Old 07-07-2011, 07:10 AM   #14
acadianbob's Avatar
Originally Posted by mtnguy View Post
I do both axles. I guess you could do just 1 axle if 1 block on each wheel is too much lift, but I would not go over a 1 block difference between the wheels.
X2. Thing only makes sense. I will also do a block difference if the ground is uneven.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 07-07-2011, 07:12 AM   #15
MtnGuy's Avatar
Originally Posted by RJHuser View Post
Wouldn't putting a board under one tire/axle overload that tire/axle?
If you were to lift 1 axle where the 2nd axle has little or no weight, then the lifted axle (& tire) could be overloaded. But I think blocking 1 axle no more than a board difference (1 1/2" to 2") from the 2nd axle should not be that great of a load......you probably encounter the equivalent of that many times on the road (going through a dip, the apron at the gas pumps, over railroad tracks, etc.). A couple of inches difference is a different story. If the unblocked tire is off the ground, your lifted axle is probably overloaded.
Old 07-07-2011, 08:01 AM   #16
Glenn5995's Avatar
It depends on the terrain. If the ground is fairly level front to rear, I will place the pads under both tires on the low side. Frequently there is a front/rear slope that when I level the trailer front/rear, will leave the suspension on one axle compressed and the other extended. In that case I may place the pads under the extended axle to level side to side and try to equalize the load. The roads/trails our 5'er has traveled frequently will have a tire hanging in the air while the other tire on the side carries all the load. So far I have had no problems, so I wouldn't be concerned about the 1" or 2" difference the pads would make.
Of course I have the yellow "lego" pads. I don't know about those orange ones.
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 07-07-2011, 08:27 AM   #17
This is in positioning the lynx levelers .....
"Determine which wheels must be raised, always leaving one wheel on the ground."
I read it to mean that one should only raise one wheel .... When they say which wheels, I assume they mean which side ..... If I am not wrong, the manual which came with the levelers had a NO icon on the picture where both axels/wheels were raised. I looked for the manual but I must have thrown it Maybe they are saying that do not use the levelers on both sides of the trailer ... why would anyone ever want to do that ? Thus I interpret it the way I did/do ...
I am just stating how I interpret what I read and remember seeing. I do raise both wheels ... Raising one wheel would increase the load on the torsion axel that particular wheel is connected to for sure.
P.S. Keep in mind English is not my native tongue and I might interpret things slightly differently .... right or wrong
Originally Posted by herk7769 View Post
Tri Lynx Levelers
Old 07-07-2011, 09:02 AM   #18
Fire Instructor's Avatar
I've always used legos one side, both axles. The legos give you 1" increments in lift, which correspond to the graduated leveling bubbles.
That said, I've read some recent discussion (on the "other" forum) that one axle, one side will give you 0.50" increments. I've never tried it, though....
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 07-07-2011, 10:37 AM   #19
Herk7769's Avatar
Now I am confused where before I was not.
I think I will continue to level "by the side" and not "by the tire" though...
Old 07-07-2011, 11:12 AM   #20
trudinator's Avatar
maybe I'm confused, but why would you level only one tire and not both tires on one side? And why would you put leveling blocks on both sides? Aren't you defeating the purpose of leveling, since you're adding height to BOTH sides? We had to build up about 3-4" on one side the last campsite we camped at. We used every orange/yellow leveling block we had, and then DH got the shovel out to dig a hole for the other side. Finally got it level. I would never even consider just leveling one tire instead of both. Seems counterproductive to me. But then again, we've only had our TT for 45 days....
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
