Old 06-28-2019, 08:00 PM   #1
Siding billowing Coachman Clipper 17FQ
Did I dream it or is there a thread on this topic somewhere on this forum. I ran a search but only found complaints about it, not solutions. At interstate speeds, the siding on the front sides of my trailer (ahead of the windows--above storage doors) billowed out so badly that the siding separated. Thankfully, it did not blow off! 1000 miles from home in 35 degree rain, I resorted to duct tape to keep the water out and finally found an ACE Hardware (Wall, SD) and popped about 25 small sheet metal screws in the seams. That held it together and reduced the "billowing" to more like "puffing". I tried squirting construction adhesive in but it did not appear to have anything to stick to...... There appears to be nothing substantial past the nose of the trailer to screw anything to. Not even window frame/extensions.
Any solutions? IS there anything to attach it to? I've even considered some sort of decoration that could be attached to the outside and then secured inside????? Wife says that's a NO. Help!
Hal
2014 Clipper FQ
2016 F150 SCrew 2.7 EcoBoost
thewheelman is offline   Reply With Quote
Old 06-28-2019, 10:50 PM   #2
bikendan's Avatar
For members, I believe that the OP's TT is stick and tin.
Equalizer WDH
Old 06-29-2019, 09:24 AM   #3
I went through the same thing with my Clipper 17BH. There are 2x2 framing studs that the siding is stapled to. I found mine by gently pressing on the paneling inside the trailer and you can feel where they are.. Gave me a reference point of where to look outside.
I did a quick fix of using some small head screws through the siding into the studs which actually held really well.
I wish I had pics, but the siding was replaced at the dealer about a month later under warranty.
That stinks being so far from home having issues like that, glad you were able to make a temporary patch. Good luck
Bzwl is offline   Reply With Quote
