Old 03-14-2019, 06:23 AM   #101
Prime Member
My 23 year old refers to these remnants as sideburns.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 03-14-2019, 07:33 AM   #102
Summit1's Avatar
The fifth brother (Groucho, Chico, Harpo, Zeppo, and Skid)?
Seriously... eleven pages and counting...
Summit1 is offline   Reply With Quote
Old 03-14-2019, 04:47 PM   #103
DavidBo's Avatar
Originally Posted by woo10-210 View Post
Gone mad? Maybe. But it was certainly an entertaining break from the normal 'can I tow this toy hauler with my '80 Volkswagen diesel pickup?' and 'I'll never buy another so-and-so again' post.
You left out "I live in the South, should I winterize"?
DavidBo is offline   Reply With Quote
Old 03-14-2019, 05:54 PM   #104
Janet H's Avatar
Wow this thread has taken on life of it's own.... epic!
Here are my suggestions for the OPs concern if none of the earlier comments were helpful:
1. Take the light bulbs out the the bathroom fixtures. (tree falling in the woods paradigm in play here).
2. Take the 7 year old kids approach and ignore the issue. When questioned about any "discoloration" simply deny any knowledge of the issue. If you need any coaching on the appropriate shoulder shrug I can rent you my kid.
3. Shift blame. Next time you lift the lid, step back and very loudly exclaim: "Who did this?! What the heck? Are you a barbarian? Get in here and clean it up - now"
4. Remove the problem entirely. Pull out the offending pot and black tank leaving an open hole to the ground (think old railroad facilities over bare tracks).
5. When you're buying your next rig (in a smaller size because you'll likely only need space for one person now) make sure it has a porcelain throne
Janet H is offline   Reply With Quote
Old 03-14-2019, 06:09 PM   #105
Grandson calls them "Hash Marks".
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 03-18-2019, 03:44 PM   #106
Carrots
This is the best reading I've ever done on a forum post. OK, I have a small world.
Anyways, I think carrots are the answer. The trick is to get farm fresh carrots with the tops attached. No, it's not about the flavour, but be patient and I'll explain. The carrots are best eaten 3 to 5 hours before the time of your normal BM deposit. It takes time for this stuff to work through the system you know. Do not throw away the carrot tops, this may be needed later. Go along with your day as you normally wood. Enjoy the sunshine, talk to the neighbours, have a coffee or other favourite beverage and then when the time is right get down to business.
Now, put the carrot tops in a bag and take them with you. Close the door, read a book, facebook, or whatever it is you do while you are busy. Once done do an inspection. If all slipped away without a trace then ditch the carrot tops in the garbage and cover with TP to hide the evidence. If traces are left, unbag the tops, wet them, add a bit of soap and then, well you know... ....give the throne a clockwise swoosh. Yes, that is all it takes. All tracks will be gone.
Cheers!
RStock is offline   Reply With Quote
Old 03-18-2019, 07:26 PM   #107
DavidBo's Avatar
I always thought of "skid marks" as...well...something else. Around here, we call what you're referring to as "reentry burns"!
