Old 03-01-2019, 12:10 AM   #1
Cmmjmoore's Avatar
Skid Marks
This is kind of embarrassing and not sure how to phrase it. I have a problem with "trails" in the toilet after its flushed.
It takes several flushes to get it clean or I have to get the bowl brush and toilet cleaner out after every time I take care of business. I realize this wouldn't be a problem if the toilet was porcelain. I even tried waxing the bowl but that only last a couple of days. Any suggestion relevant to the described problem, PLEASE! Sorry no pictures.
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
Cmmjmoore is offline   Reply With Quote
Old 03-01-2019, 12:13 AM   #2
Eat more vegetables!
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 03-01-2019, 12:19 AM   #3
RV There Yet?
IsleDog's Avatar
As a man, I will tell you that it happens to ALL toilets, from time to time. you can try paper down first, then do your business, fill the bowl up with water, flush and it should be clean. if not, just use the brush and move on with your day. no harm, no fowl.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 03-01-2019, 12:25 AM   #4
Fulltime family RVer
Paper down first seems to be the general recommendation.
Like I did with the house when we had it, I used to leave it and try to pee it off later. But that didn't always work (either place).
So now honestly, I just wipe the toilet with toilet paper after I flush and flush again.
Wash my hands well when I'm done.
Old 03-01-2019, 12:29 AM   #5
Other than replacing with porcelain, I'm not sure there is a solution.
You could try putting Calgon Liquid Watersoftener around the rim of the bowl before you do your business. That tends to coat plastic and keep stuff from sticking, but whether it would work or not is questionable.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is online now   Reply With Quote
Old 03-01-2019, 12:30 AM   #6
cavie's Avatar
You are not putting enough water in the bowl. Fill it up. Most turds flot. Ever see how much water in in the bowl at home? There is a reason for that. You need at least 1.5 gal of water.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-01-2019, 01:15 AM   #7
Fishtexx's Avatar
Put water in the bowl prior to taking care of bidness.
Terry and Laurie
2017 Flagstaff 27RLWS
2018 F-250 6.7 4X4 Crew
Fishtexx is offline   Reply With Quote
Old 03-01-2019, 07:18 AM   #8
Canadian Member
More water and more bran. If that doesn’t work, you could install a sprayer on the water line and use that and a toilet brush.
EDIT: If you want to go ECO, install a composting toilet.
2019 Rockwood Signature 8290BS
Old 03-01-2019, 07:35 AM   #9
nomad297's Avatar
Hydrophobic Coating
You can try applying a hydrophobic coating to the bowl. It will most likely work very well.
Look at the Rustoleum NeverWet kit.
Bruce
nomad297 is online now   Reply With Quote
Old 03-01-2019, 07:46 AM   #10
jeff64's Avatar
Like everyone said"s... happens". Use enough water to begin with. Don't sweat the small stuff. When you finish, put just enough water in the bowl to cover the skid marks. It will keep it from stinking and the water will dissolve it by the next time someone uses it. Close the lid. outta sight outta mind!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
